    Bias Instability of BMI088 is more than 4 Deg/hour??
    venkat57
            We have purchased 10 BMi088 sensors for our application.  We have evaluted Bias inatability of these 10 BMI088 sensors using Allan Var method at constant temperature of 25 Deg C using thermal chamber.
    But the bias instability of all sensors is above 4 deg/hour, only one sensor bias stability out of 10 sensors resulted in closer to 2 deg/hour.
    Is every BMI088 sensor factory tested and calibrated in production?
    Bias instablity is mentioned in flyer document as 2 deg/hour but Allan Plot is not printed in flyer document! why?
    Please clarify above all queries.
    Venkat
    Hi venkat57,
    We have the following questions about your Allan analysis of variance:
    What is the testing environment for conducting Allan analysis of variance?
    Does BMI088 remain stationary during the testing process? Is there any interference around?
    What are the test results for the x, y, and z axes?
    Yes, BMI088 sensor kept remain stationary during the testing process.
    Is there any interference around?__Don't understand, which interference your talking about?
    What are the test results for the x, y, and z axes?__ for 9 sensors out of 10 sensors, all x,y,z axis inrun bias stability is >= 4 deg / hour
    Thank you inadvance,
    K.Venkata Rao
