03-27-2024 01:39 PM - edited 03-27-2024 02:07 PM
Hey everyone i have problems getting a bme680 to run on an esp32 c3. if i try the example code of the bsec2 library i get the error bme680 error code -2 in the output of the serial monitor...i use the i2c communication via sda and scl in the arduino ide
I also tried to change:
BME68X_I2C_ADDR_LOW
to 0x77 but sadly same output. error code -2
Sample Code:
* Copyright (C) 2021 Bosch Sensortec GmbH
* SPDX-License-Identifier: BSD-3-Clause
/* If compiling this examples leads to an 'undefined reference error', refer to the README
* at https://github.com/BoschSensortec/Bosch-BSEC2-Library
/* The new sensor needs to be conditioned before the example can work reliably. You may run this
* example for 24hrs to let the sensor stabilize.
* basic.ino sketch :
* This is an example for illustrating the BSEC virtual outputs and
* which has been designed to work with Adafruit ESP8266 Board
#include <bsec2.h>
/* Macros used */
#define PANIC_LED LED_BUILTIN
#define ERROR_DUR 1000
/* Helper functions declarations */
* @brief : This function toggles the led when a fault was detected
void errLeds(void);
* @brief : This function checks the BSEC status, prints the respective error code. Halts in case of error
* @param[in] bsec : Bsec2 class object
void checkBsecStatus(Bsec2 bsec);
* @brief : This function is called by the BSEC library when a new output is available
* @param[in] input : BME68X sensor data before processing
* @param[in] outputs : Processed BSEC BSEC output data
* @param[in] bsec : Instance of BSEC2 calling the callback
void newDataCallback(const bme68xData data, const bsecOutputs outputs, Bsec2 bsec);
/* Create an object of the class Bsec2 */
Bsec2 envSensor;
/* Entry point for the example */
void setup(void)
/* Desired subscription list of BSEC2 outputs */
bsecSensor sensorList[] = {
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_RAW_TEMPERATURE,
BSEC_OUTPUT_RAW_PRESSURE,
BSEC_OUTPUT_RAW_HUMIDITY,
BSEC_OUTPUT_RAW_GAS,
BSEC_OUTPUT_STABILIZATION_STATUS,
BSEC_OUTPUT_RUN_IN_STATUS
/* Initialize the communication interfaces */
Serial.begin(115200);
Wire.begin();
pinMode(PANIC_LED, OUTPUT);
/* Valid for boards with USB-COM. Wait until the port is open */
while(!Serial) delay(10);
/* Initialize the library and interfaces */
if (!envSensor.begin(BME68X_I2C_ADDR_LOW, Wire))
checkBsecStatus(envSensor);
/* Subsribe to the desired BSEC2 outputs */
if (!envSensor.updateSubscription(sensorList, ARRAY_LEN(sensorList), BSEC_SAMPLE_RATE_ULP))
/* Whenever new data is available call the newDataCallback function */
envSensor.attachCallback(newDataCallback);
Serial.println("BSEC library version " + \
String(envSensor.version.major) + "." \
+ String(envSensor.version.minor) + "." \
+ String(envSensor.version.major_bugfix) + "." \
+ String(envSensor.version.minor_bugfix));
/* Function that is looped forever */
void loop(void)
/* Call the run function often so that the library can
* check if it is time to read new data from the sensor
* and process it.
if (!envSensor.run())
void errLeds(void)
while(1)
digitalWrite(PANIC_LED, HIGH);
delay(ERROR_DUR);
digitalWrite(PANIC_LED, LOW);
delay(ERROR_DUR);
if (!outputs.nOutputs)
return;
Serial.println("BSEC outputs:\n\ttimestamp = " + String((int) (outputs.output[0].time_stamp / INT64_C(1000000))));
for (uint8_t i = 0; i < outputs.nOutputs; i++)
const bsecData output = outputs.output[i];
switch (output.sensor_id)
case BSEC_OUTPUT_IAQ:
Serial.println("\tiaq = " + String(output.signal));
Serial.println("\tiaq accuracy = " + String((int) output.accuracy));
break;
case BSEC_OUTPUT_RAW_TEMPERATURE:
Serial.println("\ttemperature = " + String(output.signal));
break;
case BSEC_OUTPUT_RAW_PRESSURE:
Serial.println("\tpressure = " + String(output.signal));
break;
case BSEC_OUTPUT_RAW_HUMIDITY:
Serial.println("\thumidity = " + String(output.signal));
break;
case BSEC_OUTPUT_RAW_GAS:
Serial.println("\tgas resistance = " + String(output.signal));
break;
case BSEC_OUTPUT_STABILIZATION_STATUS:
Serial.println("\tstabilization status = " + String(output.signal));
break;
case BSEC_OUTPUT_RUN_IN_STATUS:
Serial.println("\trun in status = " + String(output.signal));
break;
default:
break;
if (bsec.status < BSEC_OK)
Serial.println("BSEC error code : " + String(bsec.status));
errLeds(); /* Halt in case of failure */
else if (bsec.status > BSEC_OK)
Serial.println("BSEC warning code : " + String(bsec.status));
if (bsec.sensor.status < BME68X_OK)
Serial.println("BME68X error code : " + String(bsec.sensor.status));
else if (bsec.sensor.status > BME68X_OK)
Serial.println("BME68X warning code : " + String(bsec.sensor.status));
3 weeks ago
Hi ptrkx,
1.Ensure your BME680 hardware was correct, and check if BME680 pin 5(SDO) was connected to GND as you set I2C address to BME68X_I2C_ADDR_LOW;
2. Could we know which BSEC version and example code you refer to?
3 weeks ago
Hey i am using BSEC2 Library: https://github.com/boschsensortec/Bosch-BSEC2-Library/tree/master/examples/generic_examples/basic
on Arduino IDE.
Hardware ESP32 C3 with BME680 via I2C
No problem with compiling, but seriell output is error code: -2
Same problem when i connect SDO to GND
