06-14-2024 07:31 AM
I have a custom nrf52840 board with a BHI260AP+BMM150+BMP390, and I was able to use the BHI260 SDK to make a custom build that provides magnetometer and barometer data from the BMM150 and BMP390 respectively.
However, looking at the BMP390 datasheet it can also provide temperature, but adding the following lines in the config:
217, 16.000000 # VirtTemperature: temperature depends on a physical temp source.
183, 16.000000 # VirtWakeupTemperature: wakeup temperature depends on a physical temp source.
06-21-2024 04:40 AM
Hi bsole,
After check, internal BHI260AP SDK supported to use BMP390 sensor data, the BHI260AP SDK on the official website does not support such use.
If you design a project with BHI260AP, you can get in contact with one of our official distributors or sales representatives to allow us to review each project on a case-by-case basis, and submit your request. Thanks for your understanding.
