06-09-2020 01:33 PM
I am considering use of a gyro from Bosch. However, I find that the datasheets are not very detailed.
I would only need Z-axis gyro, but I would need rather good stability. I can do calibration of each unit. I assume that typical values in data sheets (most are 3 degrees/sec, some 0.5) are typical uncalibrated values. Use would be only room temperature.
What is typical/max long-term stability for the different gyro sensors after calibration?
06-11-2020 07:45 AM
Please contact the local sales and support team.
03-15-2021 03:03 AM
Hello KurtM,
Can you tell me your specific requirements for gyroscope parameters? Which aspect of the data in the data sheet is not detailed enough?
You can refer to the following IMU products information from this link: https://www.bosch-sensortec.com/products/motion-sensors/imus/
04-12-2021 04:24 AM
Hello KurtM,
Close this ticket. If you have any reply in the future, you could update it here.
