    Heading Calculation
    Heading Calculation
    Error_Code
    Im using bno055 sensor for one of my project, where i need to find compensated heading. I have used sensor fusion in bno055 which gives very good result.Some how i have tried to make a filter algorithm (madgwick ) where i have observed heading with not compensated as in sensor fusion algorithm.im attaching my code below , could some one suggest any solution for the same.
    Thanks in advance.
    float calculateHeading(struct mag_float_t *mag_xyz_data)
    float mx = mag_xyz_data -> x;
    float my = mag_xyz_data -> y;
    float mz = mag_xyz_data -> z;
    // axis swapped in 9dof breakout
    float roll_rad = roll / 57.29578f; //in radians/s
    float pitch_rad = pitch / 57.29578f; //in radians/s
    float mx_compensated = (mx * cosf(pitch_rad)) + (mz * sinf(pitch_rad));
    float my_compensated = (mx * sinf(roll_rad) * sinf(pitch_rad)) + (my * cosf(roll_rad)) - (mz * sinf(roll_rad) * cosf(pitch_rad));
    float magX = mx_compensated;
    float magY = my_compensated;
    float heading = 0;
    if(magX == 0)
    if(magY < 0)
      heading = 90;
    else if(magY >= 0)
      heading = 0;
    else if(magX != 0)
    heading = atan2(magY, magX);
    heading += DEC_ANGLE; // subtraction works not adding
    heading *= (180.0f / M_PIf);
    if(heading > 360.0f)
    heading -= 360.0f;
    if(heading < 0.0f)
    heading += 360.0f;
    return heading;
    void CK_IMU_MadwickUpdate2(struct accel_float_t *acc_xyz_data,struct mag_float_t *mag_xyz_data,struct gyro_float_t *gyro_xyz_data)
    imuSyncCounter++;
    if(imuSyncCounter >= 0)
    imuSyncCounter = 0;
    float recipNorm;
    float s0, s1, s2, s3;
    float qDot1, qDot2, qDot3, qDot4;
    float hx, hy;
    float _2q0mx, _2q0my, _2q0mz, _2q1mx, _2bx, _2bz, _4bx, _4bz, _2q0, _2q1, _2q2, _2q3, _2q0q2, _2q2q3, q0q0, q0q1, q0q2, q0q3, q1q1, q1q2, q1q3, q2q2, q2q3, q3q3;
    float gx = gyro_xyz_data -> x;
    float gy = gyro_xyz_data -> y;
    float gz = gyro_xyz_data -> z;
    float ax = acc_xyz_data -> x;
    float ay = acc_xyz_data -> y;
    float az = acc_xyz_data -> z;
    // Convert gyroscope degrees/sec to radians/sec
    gx *= 0.0174533f;
    gy *= 0.0174533f;
    gz *= 0.0174533f;
    // Rate of change of quaternion from gyroscope
    qDot1 = 0.5f * (-q1 * gx - q2 * gy - q3 * gz);
    qDot2 = 0.5f * (q0 * gx + q2 * gz - q3 * gy);
    qDot3 = 0.5f * (q0 * gy - q1 * gz + q3 * gx);
    qDot4 = 0.5f * (q0 * gz + q1 * gy - q2 * gx);
    // Compute feedback only if accelerometer measurement valid (avoids NaN in accelerometer normalisation)
    if(!((ax == 0.0f) && (ay == 0.0f) && (az == 0.0f)))
    // Normalise accelerometer measurement
    recipNorm = CK_MATH_invSqrt(ax * ax + ay * ay + az * az);
    ax *= recipNorm;
    ay *= recipNorm;
    az *= recipNorm;
    // Normalise magnetometer measurement
    recipNorm = CK_MATH_invSqrt(mx * mx + my * my + mz * mz);
    mx *= recipNorm;
    my *= recipNorm;
    mz *= recipNorm;
    // Auxiliary variables to avoid repeated arithmetic
    _2q0mx = 2.0f * q0 * mx;
    _2q0my = 2.0f * q0 * my;
    _2q0mz = 2.0f * q0 * mz;
    _2q1mx = 2.0f * q1 * mx;
    _2q0 = 2.0f * q0;
    _2q1 = 2.0f * q1;
    _2q2 = 2.0f * q2;
    _2q3 = 2.0f * q3;
    _2q0q2 = 2.0f * q0 * q2;
    _2q2q3 = 2.0f * q2 * q3;
    q0q0 = q0 * q0;
    q0q1 = q0 * q1;
    q0q2 = q0 * q2;
    q0q3 = q0 * q3;
    q1q1 = q1 * q1;
    q1q2 = q1 * q2;
    q1q3 = q1 * q3;
    q2q2 = q2 * q2;
    q2q3 = q2 * q3;
    q3q3 = q3 * q3;
    // Reference direction of Earth's magnetic field
    hx = mx * q0q0 - _2q0my * q3 + _2q0mz * q2 + mx * q1q1 + _2q1 * my * q2 + _2q1 * mz * q3 - mx * q2q2 - mx * q3q3;
    hy = _2q0mx * q3 + my * q0q0 - _2q0mz * q1 + _2q1mx * q2 - my * q1q1 + my * q2q2 + _2q2 * mz * q3 - my * q3q3;
    _2bx = sqrtf(hx * hx + hy * hy);
    _2bz = -_2q0mx * q2 + _2q0my * q1 + mz * q0q0 + _2q1mx * q3 - mz * q1q1 + _2q2 * my * q3 - mz * q2q2 + mz * q3q3;
    _4bx = 2.0f * _2bx;
    _4bz = 2.0f * _2bz;
    // Gradient decent algorithm corrective step
    s0 = -_2q2 * (2.0f * q1q3 - _2q0q2 - ax) + _2q1 * (2.0f * q0q1 + _2q2q3 - ay) - _2bz * q2 * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (-_2bx * q3 + _2bz * q1) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + _2bx * q2 * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
    s1 = _2q3 * (2.0f * q1q3 - _2q0q2 - ax) + _2q0 * (2.0f * q0q1 + _2q2q3 - ay) - 4.0f * q1 * (1 - 2.0f * q1q1 - 2.0f * q2q2 - az) + _2bz * q3 * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (_2bx * q2 + _2bz * q0) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + (_2bx * q3 - _4bz * q1) * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
    s2 = -_2q0 * (2.0f * q1q3 - _2q0q2 - ax) + _2q3 * (2.0f * q0q1 + _2q2q3 - ay) - 4.0f * q2 * (1 - 2.0f * q1q1 - 2.0f * q2q2 - az) + (-_4bx * q2 - _2bz * q0) * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (_2bx * q1 + _2bz * q3) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + (_2bx * q0 - _4bz * q2) * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
    s3 = _2q1 * (2.0f * q1q3 - _2q0q2 - ax) + _2q2 * (2.0f * q0q1 + _2q2q3 - ay) + (-_4bx * q3 + _2bz * q1) * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (-_2bx * q0 + _2bz * q2) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + _2bx * q1 * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
    recipNorm = CK_MATH_invSqrt(s0 * s0 + s1 * s1 + s2 * s2 + s3 * s3); // normalise step magnitude
    s0 *= recipNorm;
    s1 *= recipNorm;
    s2 *= recipNorm;
    s3 *= recipNorm;
    // Apply feedback step
    qDot1 -= beta * s0;
    qDot2 -= beta * s1;
    qDot3 -= beta * s2;
    qDot4 -= beta * s3;
    // Integrate rate of change of quaternion to yield quaternion
    q0 += qDot1 * imu_dT;
    q1 += qDot2 * imu_dT;
    q2 += qDot3 * imu_dT;
    q3 += qDot4 * imu_dT;
    // Normalise quaternion
    recipNorm = CK_MATH_invSqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
    q0 *= recipNorm;
    q1 *= recipNorm;
    q2 *= recipNorm;
    q3 *= recipNorm;
    CK_IMU_ComputeEulerAngles();
    Hi Error_Code,
    Do you mean you would like to compensate heading value which output by the BNO055 fusion algorithm?
    BNO055 is not recommended for use in new designs. You can use BHI360 + BMM350 in new design as their combination has better performance.
    Thank you for your response,
    I didn't mean to compensate bno055 heading value. I want to know how can i implement this compensated heading just like bno055 provides.
    As you suggested , if i take  BHI360 + BMM350 for estimate  compensated heading.How can i implement it?Is there any libraries or any reference documents available for the same?If so could you please provide.
    Which filter algorithm will be good for estimate compensated headinng?
    Hi Error_Code,
    We have not publicly disclosed the implementation of the fusion algorithm, and there are no plans to make it public.
    So how can i implement the compensated  algorithm using these two sensors?
