Hello!
I am new to this. I followed the AI Studio instructions and am now at the point of having an algorithm with very aceptable accuracy that I can export. I am not clear, however, on what the next general steps are. I figure I need to use the BSEC Library. How do I open it? What is the final program that I can evaluate my test results with? The App? I'd really appreciate someone explaining the steps to me!
Hi NewToThis,
1.If you used ME688 Development Kit, you could refer the following step to check the performance of your own algorithm.
https://www.bosch-sensortec.com/media/boschsensortec/downloads/product_flyer/bst-bme688-fl001.pdf
Once you have trained an algorithm with BME AI-Studio, you can export it as “.config” and copy to the microSD card of the Development Kit. After done so, the BME688 Development Kit App will visualize the scans and results live on your phone.
2.After step 1, you could replace your algorithm to config file in BSEC2 example code, and see the performance on your device.
https://github.com/BoschSensortec/Bosch-BSEC2-Library/blob/master/examples/generic_examples/basic_co...
Hi BSTRobin,
when I copy the .config file onto the SD card, insert the SD card into the board, connect the board to the app - there is an error with the response code: BSEC_CONFIG_MISSING. It doesn't seem to be able to read the file. I already created a new BMECONFIG file. What can I do now?
Hi NewToThis,
Can you take a screenshot of your running results and the contents of your SD card?
