02-29-2024 08:31 AM
All, I need help here as well. I have 3 of the BME688 x8 Sensor, sample gathering boards by Bosch just purchased at Mouser. When I try and use them with the latest Bosch Android app to test some of the sample smells I have gathsered, it says you must have a newer version of the firmware on the feather board that drives the x8 BME688 board. No problem I think and I download the latest BSEC2 library locate the Firmware source under the examples. I then install all of the older versions of the libraries the reader says are needed and compile. At the linking step I get '.dram0.bss' will not fit in region `dram0_0_seg'. I am using everything Bosch has told me to use and have 3 $80 BME688 boards that are useless for using with the Android app. Bosch you have got some excellent technology but can do better here. My goal is to update my 3 adafruit feather boards to run Bosch's latest firmware to drive the x8 test sample board from Bosch. Can someone help please!
03-04-2024 09:15 AM
Hi SHarsany,
You can download BME688 dev kit software and mobile app from https://www.bosch-sensortec.com/software-tools/software/bme688-software/
And refer to the guide in https://www.bosch-sensortec.com/media/boschsensortec/downloads/product_flyer/bst-bme688-fl001.pdf to upgrade software to your hardware board.
03-10-2024 08:06 PM
Thanks BSTRobin. I have followed those Instructions precisely and downgraded all libraries as directed. I still get the same link error stating the data segment is too large. Is there a built version of the latest firmware that can be downloaded? I am still stuck as I follow instructions and it won't complete the link step.
