05-31-2022 12:23 PM
Hello, everyone!
This is my first time using the BMI 270. I use Max FIFO mode for initialization.
The configuration is as follows:
SPI_WRITE_BYTE(0x7D, 0x0E);
SPI_WRITE_BYTE(0x40, 0xAC);
SPI_WRITE_BYTE(0x42, 0xEE);
SPI_WRITE_BYTE(0x43, 0x08);
SPI_WRITE_BYTE(0x41, 0x02);
SPI_WRITE_BYTE(0x45, 0x00);
SPI_WRITE_BYTE(0x48, 0x00);
SPI_WRITE_BYTE(0x49, 0xC0);
SPI_WRITE_BYTE(0x7C, 0x02);
I think this has something to do with the temperature rise of the system. We want to do the external temperature compensation operation. How can I turn off the internal compensation operation?
06-01-2022 05:48 PM
Hi Rainy,
Could we know what is the working environment like as you used BMI270?
06-02-2022 05:45 AM
Tested at room temperature. The circuit temperature rises from 25 ° C to 40 ° C in one hour.
06-14-2022 03:52 AM
Hi Rainy,
The current internal compensation is enabled by default. There is no interface to disable it.
