05-19-2023 01:36 AM - edited 05-19-2023 07:31 PM
Hello
I'm using the BME680 in STMCubeIDE with a STM32WLE,
I succed in importing all the files for the bsec algo with the 'bme680_iaq_33v_300s_4d' settings.
And i used the GCC cortex M4 libalgobsec.a file
I want the library to be called by my own sleep callback function that will be triggered every 120 sec (or semething close to BSEC requirement), to read IAQ data.
So i used the files in 'BSEC_Integration_Examples'
void sleep_n(uint32_t t_us, void *intf_ptr)
//HAL_LPTIM_Counter_Start_IT(&hlptim1,(32768/ 128) * t_us); //20sec timer
//Delay_us(t_us);
int64_t get_timestamp_us()
int64_t system_current_time = 0;
// Please insert system specific function to retrieve a timestamp (in microseconds)
system_current_time =((int64_t)(HAL_GetTick())*1000);
return system_current_time;
uint32_t state_load(uint8_t *state_buffer, uint32_t n_buffer)
// Load a previous library state from non-volatile memory, if available.
// Return zero if loading was unsuccessful or no state was available,
// otherwise return length of loaded state string.
return 0;
* @brief Save library state to non-volatile memory
* @param[in] state_buffer buffer holding the state to be stored
* @param[in] length length of the state string to be stored
* @return none
void state_save(const uint8_t *state_buffer, uint32_t length)
// Save the string some form of non-volatile memory, if possible.
//SPI_Flash_Erase_4K(SECTOR_STATE_BSEC);
//SPI_Flash_Write_Bytes(SECTOR_STATE_BSEC,length+1,state_buffer);
//SPI_Flash_Sleep();
uint32_t config_load(uint8_t *config_buffer, uint32_t n_buffer)
/*memcpy(config_buffer, Selectivity_config, n_buffer);
return n_buffer;*/
return 0;
void output_ready(int64_t timestamp, float gas_estimate_1, float gas_estimate_2, float gas_estimate_3, float gas_estimate_4,
float raw_pressure, float raw_temp, float raw_humidity, float raw_gas, uint8_t raw_gas_index, bsec_library_return_t bsec_status)
int64_t timestamp_int = (int64_t)timestamp;
int32_t gas_estimate_1_int = (int32_t)gas_estimate_1;
int32_t gas_estimate_2_int = (int32_t)gas_estimate_2;
int32_t gas_estimate_3_int = (int32_t)gas_estimate_3;
int32_t gas_estimate_4_int = (int32_t)gas_estimate_4;
int32_t raw_pressure_int = (int32_t)raw_pressure;
int32_t raw_temp_int = (int32_t)raw_temp;
int32_t raw_humidity_int = (int32_t)raw_humidity;
int32_t raw_gas_int = (int32_t)raw_gas;
int32_t raw_gas_index_int = (int32_t)raw_gas_index;
int32_t bsec_status_int = (int32_t)bsec_status;
APP_LOG(TS_ON, VLEVEL_L, "Timestamp: %lld, Gas Estimate 1: %d, Gas Estimate 2: %d, Gas Estimate 3: %d, Gas Estimate 4: %d, Raw Pressure: %d, Raw Temperature: %d, Raw Humidity: %d, Raw Gas: %d, Raw Gas Index: %d, BSEC Status: %d\r\n",
timestamp_int, gas_estimate_1_int, gas_estimate_2_int, gas_estimate_3_int, gas_estimate_4_int, raw_pressure_int, raw_temp_int, raw_humidity_int, raw_gas_int, raw_gas_index_int, bsec_status_int);
Enable_sensor_BME680();
return_values_init ret;
struct bme68x_dev bme_dev;
memset(&bme_dev,0,sizeof(bme_dev));
bme_dev.intf = BME68X_SPI_INTF;
bme_dev.read = bme68x_spi_read;
bme_dev.write = bme68x_spi_write;
bme_dev.delay_us = bme68x_delay_us;
//bme_dev.intf_ptr = &communicationSetup;
bme_dev.amb_temp = 25;
ret = bsec_iot_init(BSEC_SAMPLE_RATE_ULP, 0.0f, bme68x_spi_write, bme68x_spi_read, sleep_n, state_load, config_load, bme_dev);
if (ret.bme68x_status)
/* Could not initialize BME68x */
APP_LOG(TS_ON, VLEVEL_L,"Error while initializing BME68x: %d",ret.bme68x_status);
return;
else if (ret.bsec_status)
/* Could not initialize BSEC library */
APP_LOG(TS_ON, VLEVEL_L,"Error while initializing BSEC library: %d",ret.bsec_status);
return;
Here i can see that the BME680 is initalised but when the code come to the bsec init the MCU stop working.
Also what is the code to be called when i trigger my sleep callback function (LPTIM)
05-25-2023 03:02 PM
And also do you have any exemple for only IAQ with usage of sleep.
05-28-2023 06:51 PM
@BSTRobin Any update about my issue ?
05-30-2023 08:05 AM
05-30-2023 10:57 AM
Thanks for the response it works like a charm in LP mode i can get my IAQ readings
But in ULP mode i can't get the data
Here my function modified for my sleep mode usage
void bsec_iot_loop(sleep_fct sleep, get_timestamp_us_fct get_timestamp_us, output_ready_fct output_ready,
state_save_fct state_save, uint32_t save_intvl)
/* Timestamp variables */
int64_t time_stamp = 0;
uint32_t tick_before, tick_after;
/* BSEC sensor settings struct */
bsec_bme_settings_t sensor_settings;
memset(&sensor_settings, 0, sizeof(sensor_settings));
/* BSEC sensor data */
struct bme68x_data data;
uint8_t nFieldsLeft = 0;
uint32_t bsec_state_len = 0;
uint32_t n_samples = 0;
int8_t ret_val;
opMode = sensor_settings.op_mode;
bsec_library_return_t bsec_status = BSEC_OK;
sensor_settings.next_call = 0;
// while (1)
tick_before = HAL_GetTick();
/* get the timestamp in nanoseconds before calling bsec_sensor_control() */
time_stamp = get_timestamp_us() * 1000;
if (time_stamp >= sensor_settings.next_call)
/* Retrieve sensor settings to be used in this time instant by calling bsec_sensor_control */
bsec_status = bsec_sensor_control(time_stamp, &sensor_settings);
if (bsec_status != BSEC_OK)
if (bsec_status < BSEC_OK)
APP_LOG(TS_ON, VLEVEL_L,"ERROR: bsec_sensor_control: %d\n", bsec_status);
//break;
else
APP_LOG(TS_ON, VLEVEL_L,"WARNING: bsec_sensor_control: %d\n", bsec_status);
switch (sensor_settings.op_mode)
case BME68X_FORCED_MODE:
setBme68xConfigForced(&sensor_settings);
break;
case BME68X_PARALLEL_MODE:
if (opMode != sensor_settings.op_mode)
setBme68xConfigParallel(&sensor_settings);
break;
case BME68X_SLEEP_MODE:
ret_val = bme68x_set_op_mode(BME68X_SLEEP_MODE, &bme68x_g);
if ((ret_val == BME68X_OK) && (opMode != BME68X_SLEEP_MODE))
opMode = BME68X_SLEEP_MODE;
break;
if (sensor_settings.trigger_measurement && sensor_settings.op_mode != BME68X_SLEEP_MODE)
nFields = 0;
bme68x_get_data(lastOpMode, &sensor_data[0], &nFields, &bme68x_g);
iFields = 0;
if(nFields)
do
nFieldsLeft = getData(&data);
/* check for valid gas data */
if (data.status & BME68X_GASM_VALID_MSK)
if (!processData(time_stamp, data, sensor_settings.process_data, output_ready))
return;
}while(nFieldsLeft);
/* Increment sample counter */
n_samples++;
/* Retrieve and store state if the passed save_intvl */
if (n_samples >= save_intvl)
bsec_status = bsec_get_state(0, bsec_state, sizeof(bsec_state), work_buffer, sizeof(work_buffer), &bsec_state_len);
if (bsec_status == BSEC_OK)
state_save(bsec_state, bsec_state_len);
n_samples = 0;
else{
APP_LOG(TS_ON, VLEVEL_L,"ERROR: time stamp: %d\n\r", sensor_settings.next_call);
tick_after = HAL_GetTick();
//PDEBUG("cost %u ms\r\n", tick_after - tick_before);
05-30-2023 11:17 AM - edited 05-31-2023 09:51 AM
So for the moment i'm running the sensor in LP mode with the 300s_4d config and the iaq_accuracy is changing and IAQ behave normally.
Is my utilisation of the lib is good knowing that the ULP config isn't working
