    INT2 cannot be used for any motion of BMI 270, but INT1 can be used.
    hjj
    Hello everyone, I have a problem that has troubled me for a long time.I hope I can get your help.
    I use BMI 2_ INT1 can be mapped to the external interrupt INT1 of MCU, but BMI2 is used_ INT1 cannot be mapped to external interrupt INT2.
    My code is as follows
    int any_motion_interrupt(void)
    int8_t rslt;
    /* Accel sensor and any-motion feature are listed in array. */
    uint8_t sens_list[2] = { BMI2_ACCEL, BMI2_ANY_MOTION };
    struct bmi2_int_pin_config int_cfg;
    /* Variable to get any-motion interrupt status. */
    uint16_t int_status = 0;
    /* Sensor initialization configuration. */
    struct bmi2_dev bmi2_dev;
    /* Select features and their pins to be mapped to. */
    struct bmi2_sens_int_config sens_int = { .type = BMI2_ANY_MOTION, .hw_int_pin = BMI2_INT2 };
    /* Interface reference is given as a parameter
    * For I2C : BMI2_I2C_INTF
    * For SPI : BMI2_SPI_INTF
    rslt = bmi2_interface_init(&bmi2_dev, BMI2_SPI_INTF);
    /* Initialize bmi270. */
    rslt = bmi270_init(&bmi2_dev);
    if (rslt == BMI2_OK)
    /* Enable the selected sensors. */
    rslt = bmi270_sensor_enable(sens_list, 2, &bmi2_dev);
    bmi2_get_int_pin_config(&int_cfg, &bmi2_dev);
    int_cfg.pin_type = BMI2_INT2;
    int_cfg.pin_cfg[0].lvl = BMI2_INT_ACTIVE_HIGH;/*Config INT2 rising edge trigging*/
    int_cfg.pin_cfg[0].od = BMI2_INT_PUSH_PULL;
    int_cfg.pin_cfg[0].output_en= BMI2_INT_OUTPUT_ENABLE;
    bmi2_set_int_pin_config(&int_cfg, &bmi2_dev);
    /* Set feature configurations for any-motion. */
    rslt = set_feature_config(&bmi2_dev);
    /* Map the feature interrupt for any-motion. */
    rslt = bmi270_map_feat_int(&sens_int, 1, &bmi2_dev);
    printf("Move the board\n");
    /* Loop to get any-motion interrupt. */
    do
    /* Clear buffer. */
    int_status = 0;
    /* To get the interrupt status of any-motion. */
    rslt = bmi2_get_int_status(&int_status, &bmi2_dev);
    /* To check the interrupt status of any-motion. */
    if (int_status & BMI270_ANY_MOT_STATUS_MASK)
    printf("Any-motion interrupt is generated\n");
    break;
    } while (rslt == BMI2_OK);
    return rslt;
    6 REPLIES 6
    hjj
    I'm sorry to say it again.
    I use BMI 2_ INT1 can be mapped to the external interrupt INT1 of MCU, but BMI 2_ INT2 is used cannot be mapped to external interrupt INT2.
    Hi hjj,
    Do you use BMI270 base version and refer the example code https://github.com/boschsensortec/BMI270-Sensor-API/tree/master/bmi270_examples?
    BMI270 (base)
    • Any motion, No motion, Significant motion detectors
    • Wrist worn Step counter and Step detector (Pedometer)
    • Activity change recognition
      • Still
      • Walking
      • Running
    • Wrist gestures
      • Push arm down
      • Pivot up
      • Wrist shake jiggle
      • Flick in
      • Flick out
    • Wrist wear wake up
    BMI270 Context
    • Step counter and Step detector (Pedometer)
      • Still
      • Walking
      • Running
    BMI270 Legacy
    • Orientation detector (Advanced Potrait-Landscape)
    • High-G, Low-G (Freefall) detector
    • Flat detector
    • Tap detection (Single, Double, Triple taps)
    • Smartphone Step counter and Step detector (Pedometer)
      • Still
      • Walking
      • Running
    BMI270 Maximum FIFO
    • Supports a 6kB FIFO
    Thank you very much for your reply。The basic version of BMI 270 I use。INT2 cannot be used for any motion of BMI 270, but INT1 can be used.This is what bothers me。The interrupt settings of BMI270_INT1 mapping and BMI270_INT2 mapping in MCU are identical.I don't know why the external interrupt can be triggered by using INT1 in motion, but it cannot be triggered by using INT2. I also measured the port of INT2 with an oscilloscope, and the result is no pulse.
    Hi hjj,
    We will check it and give feedback to you.
