    NICLA Sense ME Uploading Issue
    melmel923
    Currently I am trying out using the standalone example provided but when i upload it gives me this error:
    Open On-Chip Debugger 0.11.0+dev-gab95bac57-dirty (2021-05-11-10:45)
    Licensed under GNU GPL v2
    For bug reports, read
    http://openocd.org/doc/doxygen/bugs.html
    debug_level: 0
    adapter speed: 1000 kHz
    target halted due to debug-request, current mode: Thread
    xPSR: 0x01000000 pc: 0x00006dc4 msp: 0x20010000
    ** Programming Started **
    ** Programming Finished **
    shutdown command invoked
    The serial monitor also prints weird stuff.
    Hope someone know what is the issue.
    2 REPLIES 2
    kise1_off
    Re: NICLA Sense ME Uploading Issue
    Hi, melmel923!
    1. Is your Arduino IDE turned on an extended mode of compiling and uploading logs?
    If not, you can turn them in preferences. Sometimes, it can help
    2. I also tried to upload Standalone to Nicla Sense ME and then what I got in the console with extended log mode:
    From what I can see, so far, I got 2(second) DEBUG_LEVEL and you got 0 DEBUG_LEVEL
    3. Try to change the Baud rate in Serial Terminal.
    Maybe one of them will be debugging channel, which is automatically created when something happened
    Hi melmel923,
    You should run BHYFirmwareUpdate first, then run Standalone, it will work.
