06-28-2023 05:13 PM
I am testing Bosch Application Board 3.0 and Bosch BHI260AP Shuttle Board 3.0 using Development Desktop 2.0.
I am able to upload the "Bosch_APP30_SHUTTLE_BHI260_BMP390.fw" firmware to the board successfully, but there is no virtual sensor for temperature data available in the list. The pressure and IMU data are available and working.
Is there an alternative solution to developing a custom driver using SDK to get temperature data from BMP390 in this setup?
06-28-2023 05:40 PM
Hi soroush,
Could we know how do you see the virtual list and what is about your list?
06-28-2023 05:55 PM
In the Development Desktop 2.0, after uploading the "Bosch_APP30_SHUTTLE_BHI260_BMP390.fw" firmware, in the "General Settings" window there is a tab called "Virtual Sensor" where all available virtual sensors are listed. I can see all IMU virtual sensors (Acc, gyro, GRV, ...) and pressure, but no virtual sensor for temperature data.
Temperature data shows up in the list if I upload "Bosch_APP30_SHUTTLE_BHI260_BME68x.fw" firmware instead, however, BMP390 itself is a pressure/temperature sensor and I expected the BHI260AP+BMP390 firmware support that as well
07-04-2023 05:39 AM
Hi soroush,
After internal check, currently BHI260AP fw havne't support to output temperature data.
10-04-2023 04:40 PM - edited 10-04-2023 04:46 PM
Could I get the firmware `Bosch_APP30_SHUTTLE_BHI260_BMP390.fw` that @soroush mentioned, please?
Is there a link where I can download it?
