    Not able to Flash BME688 development board
    Buz-lactarius
    I downloaded BME688_Development_Kit _Software _v2.0.9 and tried to flash my 688 board (attached to Adafruit Huzzah32 board) and get the following error: "'esptool.exe' is not recognized as an internal or external command, operable program or batch file."   I tried naming a different port, re-downloading but get the same error message.    Board uploads and runs the Arduino libraries but those are different that the flashed programs as there is nothing saved as a "BMErawdata" file format, BSEC2 libraries only put a *.csv file on the sd card.Any suggestions?  Using Windows 10 latest update and latest Arduino software.
    Thank You
    Hi Buz-lactarius,
    You need to install Python on your Windows 10 before you run "esptool.exe". Firstly
    Firstly, ensure that the binary "bme68x_demo_sample.ino.bin" is updated correctly.
    Thank you Robin.  I downloaded and installed Python 3.11 Windows 64bit.  New Download "bme688_development_kit_software_v2-0-9"  When I try to Flash to designated com port 14 I get this error message.  No install yet :
    Enter COM port number (e.g. COM21)14
    esptool.py v3.3
    Serial port 14
    Traceback (most recent call last):
    File "esptool.py", line 5387, in <module>
    File "esptool.py", line 5380, in _main
    File "esptool.py", line 4687, in main
    elif args.no_stub:
    File "esptool.py", line 114, in get_default_connected_device
    _esp = chip_class(each_port, initial_baud, trace)
    File "esptool.py", line 320, in __init__
    self._port = serial.serial_for_url(port)
    File "serial\__init__.py", line 90, in serial_for_url
    File "serial\serialwin32.py", line 64, in open
    serial.serialutil.SerialException: could not open port '14': FileNotFoundError(2, 'The system cannot find the file specified.', None, 2)
    [10460] Failed to execute script 'esptool' due to unhandled exception!
    Enter any key to exit.....
    Hi Buz-lactarius,
    You should enter "COM14" instead of "14".
    Thank you for catching that. Works perfectly now!
