05-17-2023 04:09 PM
In a field sensor using BME688(s), how many sensors are required, as well recommended to guarantee accurate sensor data. I'm aware the tool used to originally train the system has 8 sensors, hopefully, a fielded system will not need more than 1 or 2.
05-18-2023 07:29 AM
Hi GordonDavid,
With 8 BME688 sensors on the dev kit, you will be able to test and gather data with more than one configuration at the same time. This significantly increases statistics and reduces development time!
You can use 8 sensors, or less than 8 sensors.
05-18-2023 07:31 AM
Thanks, In a field sensor, what is the minimum recommended number of sensors.
06-01-2023 07:24 AM
Hi GordonDavid,
There is no limit to the number of sensors in the field, and how many sensors are used depends on your application requires? The typical application is to use a sensor.
06-01-2023 07:36 AM
