02-15-2021 11:03 AM - edited 02-15-2021 11:12 AM
I'm using STM32L4 MCU (STM32L476G-EVAL) and BMI270 shuttle board.
Sometimes it works but mostly it fails to initialize. So I'm asking for your help.
My setting is as follows:
1. SPI 4-wire mode (STM32Cube_FW_L4_V1.16.0)
SPI_HandleTypeDef hSPI1; /* Inertial Management */
void MX_SPI_Init(void)
hSPI1.Instance = SPI1;
hSPI1.Init.Mode = SPI_MODE_MASTER;
hSPI1.Init.Direction = SPI_DIRECTION_2LINES;
hSPI1.Init.DataSize = SPI_DATASIZE_8BIT;
hSPI1.Init.CLKPolarity = SPI_POLARITY_LOW;
hSPI1.Init.CLKPhase = SPI_PHASE_1EDGE;
hSPI1.Init.NSS = SPI_NSS_SOFT;
hSPI1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64; /* HSE 8MHz, Full-duplex, 750.0Kbps */
hSPI1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hSPI1.Init.TIMode = SPI_TIMODE_DISABLE;
hSPI1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hSPI1.Init.CRCPolynomial = 7;
hSPI1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
hSPI1.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
HAL_SPI_Init(&hSPI1);
2. dummy_byte (https://github.com/BoschSensortec/BMI270-Sensor-API, v2.63.1)
int8_t bmi270_init(struct bmi2_dev *dev)
{ if (dev->intf == BMI2_SPI_INTF) { dev->dummy_byte = 0;/*1*/ } }
3. common.c
#define BMI270_MAX_READ_WRITE_LEN 38
static SPI_HandleTypeDef *hSPI = &hSPI1;
static uint8_t spiBuf[BMI270_MAX_READ_WRITE_LEN+1];
BMI2_INTF_RETURN_TYPE bmi2_spi_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, void *intf_ptr)
uint8_t r;
if (len == 0 || len > BMI270_MAX_READ_WRITE_LEN)
return BMI2_E_OUT_OF_RANGE;
if (reg_data == NULL)
return BMI2_E_NULL_PTR;
GpioOutputOff(SPI_CS_BMI270_GPIO_PORT, SPI_CS_BMI270_GPIO_PIN);
spiBuf[0] = reg_addr;
r = HAL_SPI_Transmit(hSPI, spiBuf, 1, 1000);
//while(hSPI->State == HAL_SPI_STATE_BUSY); // wait for xmission complete
if (r == 0)
memset(spiBuf, 0x00, sizeof(spiBuf));
r = HAL_SPI_Receive(hSPI, spiBuf, len+1, 1000);
memcpy(reg_data, &spiBuf[1], len); /* The first byte is dummy */
GpioOutputOn(SPI_CS_BMI270_GPIO_PORT, SPI_CS_BMI270_GPIO_PIN);
return (r == 0) ? BMI2_INTF_RET_SUCCESS : BMI2_E_COM_FAIL;
BMI2_INTF_RETURN_TYPE bmi2_spi_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t len, void *intf_ptr)
uint8_t r;
memcpy(&spiBuf[1], reg_data, len);
r = HAL_SPI_Transmit(hSPI, spiBuf, len+1, 1000);
void bmi2_delay_us(uint32_t period, void *intf_ptr)
uint32_t msec = period / 1000U;
if (period % 1000U != 0U)
msec++;
vTaskDelay(msec); // I'm using FreeRTOS v202012.00-LTS
int8_t bmi2_interface_init(struct bmi2_dev *bmi, uint8_t intf)
memset(bmi, 0, sizeof(struct bmi2_dev));
bmi->intf = intf;
bmi->delay_us = bmi2_delay_us;
bmi->read_write_len = BMI270_MAX_READ_WRITE_LEN;
bmi->config_file_ptr = NULL; /* Assign to NULL to load the default config file */
bmi->read = bmi2_spi_read;
bmi->write = bmi2_spi_write;
return BMI2_OK;
4. application
res = bmi2_interface_init(&bmi2_dev, BMI2_SPI_INTF);
uint8_t chipId;
res = bmi2_get_regs(BMI2_CHIP_ID_ADDR, &chipId, 1, &bmi2_dev); // It does not work without this line
res = bmi270_init(&bmi2_dev);
5. spi packet
I'm attaching an excel file. I did not check all 8K data but I think the 8K data is correct. The "load_status" is not valid.
It worked only 3 times among hundreds trials.
Would you help me please?
Hugh
03-03-2021 05:30 AM
Hi Jet,
Today, I've got a BMI270 shuttle board and it just worked without any problem.
I can say that BMI260_A2 shuttle board and BMI270 shuttle board are not compatible.
When I run Development Desktop 2.0 program with Bosch Sensortec application board 2.0, both BMI260_A2 shuttle board and BMI270 shuttle board was shown as BMI270 at the titlebar of the program. It confused us and our dealer.
Now I'll continue to develop my application using BMI270 shuttle board.
Thanks for your support,
Hugh
