11-30-2021 04:59 AM
hello Bosch,
in headerless watermark mode I can program an interrupt on int1 and read the resulting data when the bma456 is ready. The bma456 datasheet states "It is possible to select filtered or pre-filtered data as an input to the FIFO." - what does this mean in particular what is filtered versus pre-filtered data ?
Choosing between the two data types can be done through bit acc_fifo_filt_data which if 0, meaning unfiltered data, results in a sample rate of 1600Hz. This bit is by default 1 meaning data is filtered, so I believe this is the setting used in your example code fifo_watermark_headerless_mode.c ?
I already choose an output data rate through acc_adr in register ACC_CONF and this can be, for example, 100Hz. Another option for acc_adr is 1600Hz, but I believe this is a different thing compared to the 1600Hz "sample rate" referred to with respect to unfiltered data - is that correct, and if so what is the difference ? I also set the bandwidth parameter, acc_bwp, which depends on acc_perf_mode. The accelerometer digital filter can be configured through Register ACC_CONF - so what is the difference between filtered or pre-filtered data, and how does it relate to these other configuration parameters set through ACC_CONF ? If fifo_watermark_headerless_mode.c is by default with filtered data (please confirm) then what sample rate is used seeing as it is not 1600Hz ?
11-30-2021 08:16 AM - edited 12-21-2021 10:12 AM
Hello TMunb,
Normally, acc_fifo_filt_data was enable. If you used pre-filtered data, sample rate was fixed with 1600 Hz. If you used un-filtered data, sample rate was fixed with 1600 Hz.
When you used filtered data, sample rate and band width could be selected according the following descriptin.
12-01-2021 04:13 AM
hi BSTRobin,
Ok, acc_fifo_filt_data is by default = 1 meaning Filtered Data. The datasheet mentions two different terms but I'm assuming 'pre-filtered' and 'unfiltered' are the same thing - is that correct ? If unfiltered data is chosen then the datasheet says the sample rate is 1600Hz, ok. Are you saying it is also fixed to 1600Hz with the filtered data option ? But ... that with the filtered data setting I would also have the option of changing the sample rate and bandwidth as per those register settings - is that correct ? So is the 'sample rate' as referred to when the datasheet discusses filtered v pre-filtered data just another name for the 'output data rate' or odr ?
12-14-2021 12:43 AM
hi BSTRobin,
when you have some time can you please get back to me in relation to the questions in my previous post ?
Thank-you.
12-21-2021 10:23 AM
Hello TMunb,
Reply: 'pre-filtered' and 'unfiltered' indicates that the data is not filtered.
Reply: sampling rate refers to the sampling frequency of ADC, which is at the front end; ODR refers to the frequency of sensor data output after passing through the filter, which is at the back end.
