06-29-2021 03:32 AM
void BMI160_init (void)
sensor.id = BMI160_I2C_ADDR; //0x69
sensor.intf = BMI160_I2C_INTF; //0x00
sensor.read = &Acc_i2c_Read;
sensor.write = &Acc_i2c_Write;
sensor.delay_ms = &Acc_delay_ms;
rslt = bmi160_init(&sensor);
APP_ERROR_CHECK(rslt);
if(rslt == BMI160_OK){
NRF_LOG_INFO("BMI160 Initialized...");
} else {
NRF_LOG_INFO("BMI160 not Initialized...");
}NRF_LOG_FLUSH();
sensor.accel_cfg.odr = BMI160_ACCEL_ODR_1600HZ;
sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
sensor.gyro_cfg.odr = BMI160_GYRO_ODR_100HZ;
sensor.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
rslt = bmi160_set_sens_conf(&sensor);
NRF_LOG_INFO("sensor Configured...");
} else {
NRF_LOG_INFO("sensor not Configured...");
}NRF_LOG_FLUSH();
/*BMI160_INT_CHANNEL_1 = BMI160_INT_CHANNEL_1;
senosr
rslt = set_accel_orientation_int(int_config, &sensor);
bmi160_set_int_config(BMI160_ACC_ORIENT_INT,*/
void BMI_INT_init (void)
int_config.int_channel = BMI160_INT_CHANNEL_1;// Interrupt channel/pin 1
int_config.int_type = BMI160_ACC_ORIENT_INT;// Choosing Any motion interrupt
int_config.int_pin_settg.output_en = 1; /* 0- output disabled ,1- output enabled */
int_config.int_pin_settg.output_mode = 0; /*! 0 - push-pull 1- open drain,only valid if output_en is set 1 */
int_config.int_pin_settg.output_type = 0; /*! 0 - active low , 1 - active high level.
* if output_en is 1,this applies to interrupts,else PMU_trigger */
int_config.int_pin_settg.edge_ctrl = 1; /*! 0 - level trigger , 1 - edge trigger */
int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_NONE;// non-latched output
/* Select the Any-motion interrupt parameters */
int_config.int_type_cfg.acc_orient_int.orient_mode = 3;// 1- Enable the any-motion, 0- disable any-motion
int_config.int_type_cfg.acc_orient_int.orient_blocking = 3;// Enabling x-axis for any motion interrupt
int_config.int_type_cfg.acc_orient_int.orient_hyst = BMI160_ENABLE;// Enabling y-axis for any motion interrupt
int_config.int_type_cfg.acc_orient_int.orient_theta = BMI160_ENABLE;// Enabling z-axis for any motion interrupt
int_config.int_type_cfg.acc_orient_int.orient_ud_en = 1;// any-motion duration
int_config.int_type_cfg.acc_orient_int.axes_ex = 1;// (2-g range) -> (slope_thr) * 3.91 mg, (4-g range) -> (slope_thr) * 7.81 mg, (8-g range) ->(slope_thr) * 15.63 mg, (16-g range) -> (slope_thr) * 31.25 mg
int_config.int_type_cfg.acc_orient_int.orient_en = 1;// (2-g range) -> (slope_thr) * 3.91 mg, (4-g range) -> (slope_thr) * 7.81 mg, (8-g range) ->(slope_thr) * 15.63 mg, (16-g range) -> (slope_thr) * 31.25 mg
/* Set the Any-motion interrupt */
rslt = bmi160_set_int_config(&int_config, &sensor); /* sensor is an instance of the structure bmi160_dev */
NRF_LOG_INFO("interrupt Initialized...");
} else {
NRF_LOG_INFO("interrupt not Initialized...");
}NRF_LOG_FLUSH();
int_status_sel = BMI160_INT_STATUS_ALL;
bmi160_get_int_status(int_status_sel, &int_status, &sensor);
if(int_status.bit.orient_1_0)
printf("success");
int main(void)
bool erase_bonds;
// Initialize.
log_init();
timers_init();
buttons_leds_init(&erase_bonds);
power_management_init();
ble_stack_init();
scheduler_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
buffer_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("HID Keyboard example started.");
timers_start();
advertising_start(erase_bonds);
twi_init();
BMI160_init();
BMI_INT_init();
initDT();
// Enter main loop.
for (;;)
//idle_state_handle();
//int_status_sel = BMI160_INT_STATUS_ALL;
//rslt = bmi160_get_int_status(int_status_sel, &int_status, &sensor);
// NRF_LOG_INFO("DataX:%d", int_status.bit.low_g);
read_sensor_data();
//NRF_LOG_FLUSH();
//read_sensor_data();
//CalibAccel();
/*calcDT();
calcAccelYPR();
calcGyroYPR();
calcFilteredYPR();
NRF_LOG_INFO("DataX:%d,DataY:%d,DataZ:%d", tmp_angle_x,tmp_angle_y,tmp_angle_z);
NRF_LOG_FLUSH();
nrf_delay_ms(100);
i want to use orientation recognize interrupt...
but i do not read int_status.bit.orient_1_0.
Let me know if there's any error.
06-29-2021 05:34 AM
Hello jayden,
Do you read int_status.bit.orient_1_0 in read_sensor_data()?
06-30-2021 03:35 AM
is this read interrupt1_0 reading data??
06-30-2021 04:32 AM
Hello Jayden,
bmi160_get_int_status() function could read all interrupt status(0x1C~0x1F).
I setup software on MCU, when I move the board left and right, MCU can receive the interrupt. It read the interrupt status in the interrupt service program and print it out. You can see the change in the value of 0x1f.
bmi160_get_int_status(BMI160_INT_STATUS_ALL, &int_status, dev);
int8_t Open_BMI160_ORIENTATION(struct bmi160_dev *dev)
int8_t rslt = BMI160_OK;
int_config.int_pin_settg.output_mode = BMI160_DISABLE;// Choosing push-pull mode for interrupt pin
int_config.int_pin_settg.output_type = BMI160_ENABLE;// Choosing active high output
int_config.int_pin_settg.edge_ctrl = BMI160_ENABLE;// Choosing edge triggered output
/* Select the orientation interrupt parameters */
int_config.int_type_cfg.acc_orient_int.orient_en = BMI160_ENABLE;//
rslt = bmi160_set_int_config(&int_config, dev); /* sensor is an instance of the structure bmi160_dev */
return rslt;
