    could i use the function BSX_S8 bsx_get_gyrocordata_rps(ts_dataxyzf32*) in BSXLITE fusion library
    blues
    Re: could i use the function BSX_S8 bsx_get_gyrocordata_rps(ts_dataxyzf32*) in BSXLITE fusion librar
    i think the range is from -2g  to 2g m/s2.
    so if the data is 32768,and the output is 2g m/s2.
    right?
    Vincent
    It is depending on the physical sensor setting.
    If you set the sensor to 2G range,  then the lib output full range is +-2G.
    If you set the sensor to 4G range,  then the lib putput full range is +-4G.
    BSX lite is just calculation the sensor data
