3 weeks ago
We are working on a sensor system that has to orientate itself in an underground pipe network. In the current version of the hardware, a BNO055 is used to record the distance travelled in the pipe system (+/- 20%) for later analysis. When reviewing the parts list, we realised that the BNO055 is not recommended for new designs. However, when looking for alternatives, we realised that there is no direct replacement for the 9DOF sensor, only intelligent 6DOF sensor systems to which a magnetometer can be connected. However, it is important for us to use a component that does not require any major adjustments to the current firmware. The answers in the community under the keyword ‘BNO055 Production Status’ are not very detailed.
- What are the reasons that Bosch and its competitors are not producing new generations of 9DOF sensors?
- Is there a direct software replacement for the BNO055?
- Does a 9DOF sensor make sense in the field of application described or is the magnetometer not suitable for this or does it not offer any added value?
- Can you recommend a sensor system directly for the application?
