    running BHI160B I can't install virtual sensor with bhy_enable_virtual_sensor
    Eyalb
    running BHI160B I can't install virtual sensor. Basically, I use example code. I call bhy_enable_virtual_sensor to set VS_TYPE_GYROSCOPE_UNCALIBRATED and it returns no error, but when I read
    with bhy_get_wakeup_sensor_information and bhy_get_non_wakeup_sensor_information I get :
    Supported Virtual Sensor Information:
    wakeup_sensor_type=158
    wakeup_sensor_type= 0
    wakeup_sensor_type=138
    wakeup_sensor_type=90
    wakeup_sensor_type=242
    wakeup_sensor_type=80
    non_wakeup_sensor_type=158
    non_wakeup_sensor_type= 0
    non_wakeup_sensor_type=138
    non_wakeup_sensor_type=90
    non_wakeup_sensor_type=242
    non_wakeup_sensor_type=80
    Re: running BHI160B I can't install virtual sensor with bhy_enable_virtual_sensor
    Are you  working on our Application board 2.0 with BHI160B? And running on COINES or Development Desktop 2.0 or other IDE?
    Could you elaborate more about your environment?
    Eyalb
    I am running on intel i7 core as application on vxworks OS . I have a mother board with FPGA that includes I2C controller and interrupt controller.
    Those I2C & interrupt controller are now connected to BHI160B evaluation board. In the evaluation board I set only internal ACC & Gyro.
    I load firmware : Bosch_PCB_7183_di03_BMI160-7183_di03.2.1.11696_170103.h and get Meta EVT 0x10 - init OK.
    then I try to enable ACC and/or Gyro and it seems to fail. I get no interrupts.
    I received interrupt while init and for init success meta-evt and also for timestamp LSB & MSB.
    Vincent
    Can you give some detail about the failure here?
    Better to share with us your schematic around BHI160B and also the meta event type 4 and 11 from your sensor after you enable the virtual sensor.
    Please also share your source code if possible.
