BME 280 pressure data readings
Hi, I am trying the use the BME280 to get pressure and temperature readings.  I have set 8X oversampling, though am not sure what the oversampling does or if it should be set to a different value.  I also am using the 32-bit integer version of the compensation equations for temp and pressure.  I seem to be getting the correct results for temperature, but the pressure reading is incorrect.  I keep getting a value in the 60000's when the test measurements are at a location near sea level.
Any advice on setup parameters, or if someone has a sample set of raw results from registers pressure and temperature and the expected results so I can validate my implementation of the compsensation equations.
Best reply by Inactive Member
A spreadsheet was shared in this post that can be used to validate your implementation of the compensation formulas, but note that you will need to feed-in your own trimming values (unique for each sensor) on top of your ADC values. Also keep in mind that it is mandatory to carry t_fine from the temerature compensation over to the pressure compensation formula. We generally strongly recommend using our official sensor API to interact with the BME280.
I would suggest the chapter "Recommended modes of operation" from BME280's datasheet (currently chapter #3.5) to find some examples of settings for different applications.
