01-31-2023 03:00 PM
I have downloaded the linux version, unzip and run successfully the login commands. But when I try to run docker-compose (inside the right folder) I get an error message saying:
Can't find a suitable configuration file in this directory or any parent. Are you in the right directory?
Inside the server folder, there are just three files:
- bst-bme-aistudio-server
- LICENSE
- README.md
What's going on?
Am I missing a file or should I run a different command?
09-04-2023 05:17 AM
Hi estani,Jimbo,
You could refer to the on line document https://www.bosch-sensortec.com/software/bme/docs/overview/server-app.html, and try it again.
09-05-2023 03:41 PM
That doc has nothing about the docker setup. It just points back to readme that is incomplete. I just need a example docker-compose.yaml file. Does anyone have a working Linux AI-Studio Serve?
Jim...
09-06-2023 04:14 AM
Hi Jimbo,
You can click on the entry link and refer to the detailed information.
09-10-2023 02:17 PM
Hi
I have the same problem, did you find any example or docker-compose yaml file working?
09-10-2023 02:19 PM
Hi
sincerely, this refers to the same links we downloaded at the beginning.
In the readme file, there is no example of docker-compose. can you please provide us with more information or docker-compose.yml file ?
