07-03-2019 02:12 PM - edited 07-03-2019 02:13 PM
I'm trying to use the rs232 communication instead of the USB on the Application board 2.0 with the BMP388 shuttle board.
There is two rs232 on the board, one for the debug and one for the communication (on the 36 pins connector). I already tried several configurations for the power supply (jumper and power switch, with external alimentation or via USB).
Is there a specific configuration for the rs232 communication ? (i followed the datasheet).
Thank you in advance
board : https://www.bosch-sensortec.com/bst/support_tools/application_boards/overview_application_boards
Datasheet : https://ae-bst.resource.bosch.com/media/_tech/media/application_board_2_0/BST-DHW-AN001-01_APP2_0_Ha...
07-04-2019 09:28 AM
07-04-2019 10:25 AM - edited 07-04-2019 10:25 AM
The User Manual says that i can use a COM interface with the RS232 or Bluetooth.
I tried to use it with the Rx and Tx (with a usb converter) on J106, however it didn't worked while it works with the USB. So i guess there is something i'm missing since there is 2 rs232 on the board, one for debug and one for an alternative way to connect the board.
Is there a specific firmware to use the J106 rs232 instead of the USB ?
User Manual (p19) : https://ae-bst.resource.bosch.com/media/_tech/media/development_desktop_software/Development_Desktop...
07-04-2019 11:35 AM
07-04-2019 12:31 PM
No it didn't worked, is there a specific jumper configuration ? Does the COM requires a specific way to power the device ? (I haven't tried using a battery, i tried External 3V3 and Usb maybe the rs232 needs 5V)
Thank you for your quick answer
