    Send data from BHI360 using bluetooth module on Application board 3.0
    Newguy
    Hello, I have read from BST-DHW-AN013.pdf that COINES can print messages through Bluetooth as seen in section 7 below. But what is bt_w in this case, how do I import it, and is there an example file in COINES?
    FAE_CA1
    Please see the attached document about how to log sensor data from APP3.0 to PC via BLE connection.
    The instruciton does not mention how to install scan.py and ble_NUS.py.
    Can you tell me how to download those?
    FAE_CA1
    The source code of scan.py and ble_NUS.py are in the PDF file. You can copy the source codes into Notepad and then save them as scan.py and ble_NUS.py respectively. Then you can run them in the Python environment such as Anaconda3.
