#Global Configuration
stuffelf,13
irq,0
evcfg,0,0,0,0,0,0,0,0,0,0,0,0
#Pin, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27
pull, off, on, off, off, on, off, on, on, off, off, off, off, off, off, off, off, off, on, on, on, on, off, on, off, on, off, off, off
gpio, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz, hiz
sif_cfg,1
hif_disable,0
fifo,50.00
wordsreq,0
turbo,0
rom,0
build_type,all
rom_name,bosch_rom
hw,7189
version,0
#Any Accel + Any Gyro + BMM150Mag_aux
config_list,libs/BSX/SolutionList/csvList_SENSORHUB_BHY2_AMG_5.txt
#Physical Drivers
#DriverID,Bus,Addr,GPIO,Cal0,Cal1,Cal2,Cal3,Cal4,Cal5,Cal6,Cal7,Cal8,Off0,Off1,Off2,maxRate,Range
32,spi0,25,2, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 800.000000, 0 #BHI260Accel
33,spi0,25,-, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 800.000000, 0 #BHI260Gyro
24,spi0,25,-, 1, 0, 0, 0, -1, 0, 0, 0,-1, 0, 0, 0, 50.000000, 0 #BMM150Mag_aux
62,i2c1,119,-, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -1.000000, 0 #BME280Pressure
63,i2c1,119,-, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -1.000000, 0 #BME280Humidity
61,i2c1,119,-, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -1.000000, 0 #BME280Temperature
#Virtual Drivers,maxRate
219, 16.000000 # VirtHumidity: humidity depends on a physical humidity source.
217, 16.000000 # VirtTemperature: temperature depends on a physical temp source.
184, 16.000000 # VirtPressure: pressure depends on a physical pressure source.
240, -1.000000 # VirtBSX: BSX depends on a programatic trigger source.
241, 400.000000 # VirtBSXAccel: accelerometer corrected data depends on VirtBSX.
209, 400.000000 # VirtBSXAccelOffset: accelerometer offset data depends on VirtBSX.
205, 400.000000 # VirtBSXAccelPassthrough: accelerometer passthrough data depends on VirtBSX.
203, 400.000000 # VirtBSXAccelUncal: accelerometer raw data depends on VirtBSX.
235, -1.000000 # VirtBSXActivity: activity depends on VirtBSX.
163, -1.000000 # VirtBSXDeviceOrientation: device orient depends on VirtBSX.
252, 400.000000 # VirtBSXGameRotation: game RotationVector depends on VirtBSX.
253, -1.000000 # VirtBSXGeoRotation: mag RotationVector depends on VirtBSX.
234, -1.000000 # VirtBSXGlanceGesture: glance gesture status depends on VirtBSX.
247, 400.000000 # VirtBSXGravity: gravity depends on VirtBSX.
243, 400.000000 # VirtBSXGyro: gyro corrected data depends on VirtBSX.
208, 400.000000 # VirtBSXGyroOffset: gyro offset data depends on VirtBSX.
207, 400.000000 # VirtBSXGyroPassthrough: gyro passthrough data depends on VirtBSX.
244, 400.000000 # VirtBSXGyroUncal: gyro raw data depends on VirtBSX.
246, 400.000000 # VirtBSXLinearAccel: linaccel depends on VirtBSX.
242, -1.000000 # VirtBSXMag: mag corrected data depends on VirtBSX.
210, -1.000000 # VirtBSXMagOffset: mag offset data depends on VirtBSX.
206, -1.000000 # VirtBSXMagPassthrough: mag passthrough data depends on VirtBSX.
245, -1.000000 # VirtBSXMagUncal: mag raw data depends on VirtBSX.
254, 400.000000 # VirtBSXOrientation: orient depends on VirtBSX.
233, -1.000000 # VirtBSXPickupGesture: pickup gesture status depends on VirtBSX.
251, 400.000000 # VirtBSXRotation: RotationVector depends on VirtBSX.
250, -1.000000 # VirtBSXSigMotion: sigmotion depends on VirtBSX.
249, -1.000000 # VirtBSXStepCounter: step count depends on VirtBSX.
248, -1.000000 # VirtBSXStepDetect: step detect depends on VirtBSX.
236, -1.000000 # VirtBSXTiltDetector: tilt detect depends on VirtBSX.
192, 400.000000 # VirtBSXWakeupAccel: wakeup accelerometer corrected data depends on VirtBSX.
204, 400.000000 # VirtBSXWakeupAccelUncal: wakeup accelerometer raw data depends on VirtBSX.
164, -1.000000 # VirtBSXWakeupDeviceOrientation: wakeup device orient depends on VirtBSX.
200, 400.000000 # VirtBSXWakeupGameRotation: wakeup game RotationVector depends on VirtBSX.
201, -1.000000 # VirtBSXWakeupGeoRotation: wakeup mag RotationVector depends on VirtBSX.
232, -1.000000 # VirtBSXWakeupGesture: wakeup gesture status depends on VirtBSX.
198, 400.000000 # VirtBSXWakeupGravity: wakeup gravity depends on VirtBSX.
194, 400.000000 # VirtBSXWakeupGyro: wakeup gyro corrected data depends on VirtBSX.
195, 400.000000 # VirtBSXWakeupGyroUncal: wakeup gyro raw data depends on VirtBSX.
197, 400.000000 # VirtBSXWakeupLinearAccel: wakeup linaccel depends on VirtBSX.
193, -1.000000 # VirtBSXWakeupMag: wakeup mag corrected data depends on VirtBSX.
196, -1.000000 # VirtBSXWakeupMagUncal: wakeup mag raw data depends on VirtBSX.
160, -1.000000 # VirtBSXWakeupMotionDetect: wakeup motion detect depends on VirtBSX.
202, 400.000000 # VirtBSXWakeupOrientation: wakeup orient depends on VirtBSX.
199, 400.000000 # VirtBSXWakeupRotation: wakeup RotationVector depends on VirtBSX.
161, -1.000000 # VirtBSXWakeupStationaryDetect: wakeup stationary detect depends on VirtBSX.
231, -1.000000 # VirtBSXWakeupStepCounter: wakeup step count depends on VirtBSX.
230, -1.000000 # VirtBSXWakeupStepDetect: wakeup step detect depends on VirtBSX.
162, -1.000000 # VirtBSXWakeupWristTiltGesture: wakeup wrist tilt gesture status depends on VirtBSX.
224, -1.000000 # VirtHangDetection: hang detector depends on a 25Hz timer.
I configured it according to the ID, and then compiled and uploaded the firmware. Now I can read the temperature, but the pressure and humidity cannot be read? Any suggestions?
