09-05-2022 10:30 AM - edited 09-05-2022 10:37 AM
Dear Community,
I wanted to achieve an ODR from the Rotation Vector virtual sensor of the BHI260AP of 800 Hz. In order to achieve so, I need to set the turbo mode, writing on the chip control register.
I have some concerns regarding the firmware that I need to use. Currently, I am using Bosch_APP30_SHUTTLE_BHI260_aux_BMM150.fw.h from BHY2-Sensor-API/firmware/bhi260ap at master · BoschSensortec/BHY2-Sensor-API · GitHub
I see that on that page there is also "turbo" firmware, but with no reference to the BMM150, nor to the fact that it's connected to the auxiliary interface. What should I do in this case? Consider that in my final custom board I will connect the BHI and the BMM as it's done in the shuttle board, and I will access the BHI using I2C.
Thanks a lot,
Dario
09-06-2022 08:35 AM
Hi dariosortino,
Bosch_APP30_SHUTTLE_BHI260_turbo_aux_BMM150.fw was not released on github.
The attachment is the generated firmware and *.h file for your reference. You can also compile and generate the firmware yourself.
Download SDK for BHI260AP (with BSX) SDK v1.1.8.0 from https://www.bosch-sensortec.com/products/smart-sensors/bhi260ap/
Refer BHI260 SDK start guide https://www.bosch-sensortec.com/media/boschsensortec/downloads/application_notes_1/bst-bhi260ab-an00..., setup your development environment, build SDK.
Add file Bosch_APP30_SHUTTLE_BHI260_turbo_aux_BMM150 to folder "BHI260AP_SDK_1.1.8.0\boards" and add "Bosch_APP30_SHUTTLE_BHI260_turbo_aux_BMM150" to file "BHI260AP_SDK_1.1.8.0\common\config.7189_di03_rtos_bhi260.cmake".
############################## Board Configurations ##############################
IF(NOT BOARDS)
set(BOARDS
Bosch_APP30_WRD_BHI260_turbo
Bosch_APP30_WRD_BHI260_BMP390
Bosch_APP30_WRD_BHI260_BME68x
Bosch_APP30_WRD_BHI260_aux_BMM150
Bosch_APP30_SHUTTLE_BHI260_BMP390
Bosch_APP30_SHUTTLE_BHI260_BME68x
#Example data injection firmware
#DataInject
#DataInject_nobsx
ENDIF()
Rebuild SDK, then you can find firmware file "Bosch_APP30_SHUTTLE_BHI260_turbo_aux_BMM150.fw" under "BHI260AP_SDK_1.1.8.0\release\gccfw" folder
There is tool which could convert firmware file to "*.h" file under "C:\COINES\v2.7.0\examples\bhy2\examples\fw2h" after you installed Coines software.
Run mingw32-make to compile this tool, and you can convert Bosch_APP30_SHUTTLE_BHI260_turbo_aux_BMM150.fw to Bosch_APP30_SHUTTLE_BHI260_turbo_aux_BMM150.fw.h by the command:
fw2h.exe Bosch_APP30_SHUTTLE_BHI260_turbo_aux_BMM150.fw
09-13-2022 05:14 PM
Thank you Robin!
Super helpful explanation!
