    BHI360 + BMM350 custom board D.D2.1 Test error
    kyusanglee
    hello
    There was an error during BHI360+BMM350 custom board D.D2.1 Test.
    I tried the same thing while looking at the How to play with BHI360 shuttle board 3.0 v1.pdf file.
    However, if you look at the Physical sensor working status item, the connection is normal.
    The flow in the graph is not visible.
    COINS also shows an error as shown in the picture.
    I would appreciate it if you could let me know the solution.
    FAE_CA1
    Sorry about the error you got.
    Could you please try to download another RAM patch "Bosch_Shuttle3_BHI360_BMM150.fw" to see if you can get the three plots changing? You may also try to download another RAM patch "Bosch_Shuttle3_BHI360.fw" which will give you 6DoF sensor fusion results.
    kyusanglee
    There is no response even with other ROM patch combinations (BHI360 + BMM150).
    Photo 1 is BHI360+BMM150 setup.
    Photo 2 is a combination of BHI360+BMM150
    Photo 3-1 is applied while looking at the settings of the How to play with BHI360 shuttle board 3.0 v1.pdf file.
    In Photo 3-2, I want to see the BMM350 value, but I don't know how to apply it.
    Please tell me how I can see graph changes in DD2.1.
    Additionally, I would appreciate it if you could let me know about COINS.
    FAE_CA1
    Have you tried to download RAM patch "Bosch_Shuttle3_BHI360.fw" to see if you can get 3 plots' waveforms changing? If it still doesn't work, then please try another APP3.0 board and BHI360 shuttle board.
    DD2.1 SW gives you graphic evaluation on our sensors, while COINES provides low level C programming to evaluate our sensors. This means that in DD2.1 SW users can only access registers with read/write. But with COINES users can write their own code to develop their own algorithms for our sensors.
    kyusanglee
    Thanks for your reply.
    I downloaded the "Bosch_Shuttle3_BHI360.fw" you mentioned and confirmed that only the gravity waveform appears.
    Please check if the settings are correct.
    If not, please tell me how to set it up.
    If the problem is that the three waveforms are not displayed, should I use another APP3.0 board and BHI360 shuttle board as you mentioned?
