04-17-2024 09:30 AM
hello
There was an error during BHI360+BMM350 custom board D.D2.1 Test.
I tried the same thing while looking at the How to play with BHI360 shuttle board 3.0 v1.pdf file.
However, if you look at the Physical sensor working status item, the connection is normal.
The flow in the graph is not visible.
COINS also shows an error as shown in the picture.
I would appreciate it if you could let me know the solution.
04-22-2024 04:15 AM
Yes, please try another APP3.0 board and BHI360 shuttle board. If you get the same problem, then please send me a private message with your company name, your company email address and your name included. I will connect you to a local FAE to support you.
