    BME 680 Gas resistance adc reading 0
    The_DudE
    I'm using the BME680 and I'm facing a problem with GAS Resistance measurements.
    Here is my setup:
    • - custom board, 3v3, I2C connection
    • -  BSECv1.4.7.3 used within barebone ARM-M4F/GCC environment
    • - main code mimicking "bsec_iot_example", using "LP" or "ULP" measure rate
    I first thought everything worked fine as I'm getting Temp,Pressure and RH values nicely correlating with measured environment, but even after a few days (weeks) of running measurements, I could still not make any sense of IAQ values.
    It turns out that the GAS_RAW value is stuck to a high value corresponding to an adc reading of zero (gas_r=0 and gas_range =0).
    I checked requested heater temperature and time (given by BSEC) and it looks correct (320 C/ 197ms in 3 seconds "LP" setup).
    When fetching results I always get gas_valid and heat_stab bits set, thus the measurement seems to be correctly performed.
    I traced the first seconds of measurements of a brand new BM680 and I saw that adc reading are actually moving:
    18:46:07:642 [DRV 3] calc_gas_resistance: adc:392 range:11 -> 4291.02
    18:46:10:634 [DRV 3] calc_gas_resistance: adc:960 range:9 -> 11720.93
    18:46:13:633 [DRV 3] calc_gas_resistance: adc:379 range:8 -> 34713.96
    18:46:16:635 [DRV 3] calc_gas_resistance: adc:413 range:7 -> 68053.58
    18:46:19:638 [DRV 3] calc_gas_resistance: adc:616 range:6 -> 116028.30
    18:46:22:641 [DRV 3] calc_gas_resistance: adc:619 range:5 -> 229796.34
    18:46:25:643 [DRV 3] calc_gas_resistance: adc:839 range:4 -> 401811.03
    18:46:28:646 [DRV 3] calc_gas_resistance: adc:309 range:4 -> 588290.75
    18:46:31:648 [DRV 3] calc_gas_resistance: adc:879 range:3 -> 785630.88
    18:46:34:651 [DRV 3] calc_gas_resistance: adc:533 range:3 -> 984626.62
    18:46:37:653 [DRV 3] calc_gas_resistance: adc:310 range:3 -> 1176727.88
    18:46:40:659 [DRV 3] calc_gas_resistance: adc:187 range:3 -> 1318627.50
    18:46:43:658 [DRV 3] calc_gas_resistance: adc:80 range:3 -> 1473165.38
    18:46:46:661 [DRV 3] calc_gas_resistance: adc:860 range:2 -> 1588895.38
    18:46:49:664 [DRV 3] calc_gas_resistance: adc:687 range:2 -> 1769736.62
    18:48:22:741 [DRV 3] calc_gas_resistance: adc:825 range:0 -> 6489747.00
    18:49:34:803 [DRV 3] calc_gas_resistance: adc:366 range:0 -> 8974145.00
    18:50:13:837 [DRV 3] calc_gas_resistance: adc:221 range:0 -> 10208728.00
    18:56:32:915 [DRV 3] calc_gas_resistance: adc:0 range:0 -> 12946861.00
    but after a few minutes the values reaches 0 and stays stuck. I understand ther is a "burn-in" phase for MOX sensors, but I guess it should not "burn" down to zero...
    After unplugging/unpowering the BM680 for a while and restarting, I get back some "life" on adc measurements (starting lower than the very first time though), but following the same steep curve to zero. I tried 4 different boards with same result.
    Does it ring a bell to anyone ? What could be my problem here ? I can give more detailed info about registers setup (even though I'm just following BSEC requests).
    Laurent
    22 REPLIES 22
    The_DudE
    I had a look to the HSMI document and it states:
    The vent hole of the sensor shall be covered with a silicone-free protective layer during processing (e.g. cleaning, soldering, board wash etc.) to prevent possible contamination
    How is this supposed to be done by the PCBA? If this is a real requirement, shouldn't the BME come with a removable protective cover (like some others Hydro or Baro chips) ?
    handytech
    This requirement is real, although it may depend on your actual PCBA processes. Unfortunately we do not sell any of our sensors with removable protective covers, therefore one suggestion would be to evaluate for example Kapton tape to cover the hole of the sensor during assembly.
    The_DudE
    Although it could be ok for a small manually placed batch, I don't really see how putting tape on each chip will be feasible for a real assembly run as:
    - getting chips out of the reel for putting the protective tape (cutting it into BME sized pieces beforehand...), then you can not use pick and place machine anymore (reconditionning into reel is not an option).
    - Putting the tape after pick & place will certainly compromise placement.
    I guess that reflow part (not vapour-phase oven) should be harmless for the BME (unlike cleaning/washing), so it might  be enough to put protecting cover after reflow ?
    Don't you have an example of PCBA process flow that is known to work with or without protective cover ?
    handytech
    Correct.
    We would strongly recommend to get in touch directly with your manufacturer about this topic, as they probably already have some experience about this and could recommend the best practices with the tools already available to them.
    The_DudE
    Ok, I'll try the "protect-after- reflow" option in a next proto batch.
    Thanks for your support.
    Laurent
