    BME 688 burn in process
    fritz
    According to the recommendations the BME 688 sensor should be stabilized by running for at least for 24 hours.
    For this purpose I'm using HP-354 profile with RDC-1-0 continous readings.
    After appr. 30 hours the gas resistance readings seemed to be stable (see attached plot), but rises again later.
    How could one explain such a behaviour?
    Still needed more time to stabilize ?
    2 REPLIES 2
    fritz
    ... performing burn-in process for additional hours (60h) doesn't really helps, RAW gas resistance readings
    are still oscillating significantly.
    Hi fritz,
    Take LP mode as an example:
    The IAQ value obtained within 8 hours is not credible, and it can be obtained after more than 8 hours。
    After 7 days, based on similar baseline, the output value of different sensor in the same environment should be within the scope of the specification, ± 15+± 15%.
