Has anyone used the BME280 driver on a 8 or 16 bit micro(SiLabs, PIC...etc)? If so, can you point me in the general direction of how you approached this? Thanks so much.
You means that you need a success solution that already use BME680 with 8/16 bit MCU, is that right?
Best regards.
THe 280. There are tons of "drivers" out there for it using the RPI or 32bit ARM cores. I just haven't found anything for an 8 bit micro. I just wanted to hear from someone that's developed one to get an indication on any pitfalls I might encounter.
