    BME680 BSEC library issue
    mgchoi
    Hello, BOSCH
    I downloaded BSEC before and am testing it.
    I am sending you an email because I have an inquiry during the test regarding the library.
    If you compare the files you used among the links you sent me last time
    It is estimated that the actual version used is "BSEC_1.4.8.0_Generic_Release_updated_v3".
    (The internal sauce is being modified a little, so it's not completely the same.)
    1. List of gcc-enabled files in an existing compiler (STM32CubeIDE)
    2. List of files currently using armcc in the compiler (Keil MDK-ARM)
    At the time of the last test, I accidentally tested the BME680 without connecting it, so I thought there was no problem,
    I connected the BME680 and tested it again, and it no longer progressed in the bsec_init(); below.
    The above part has a function in the libalgobsec.lib library that you provide, so accurate debugging is impossible.
    I don't think the library version is a problem, but it hasn't progressed since bsec_init(); so please check this part.
    6 REPLIES 6
    Hi mgchoi,
    I upload BSEC_1.4.8.0 example code on STM32F4 for your reference, hope it is helpful for you.
    HI, BST Robin
    Currently, I am using the file list (Keil MDK-ARM) that uses armcc, so can I ask for that file?
    Hi mgchoi,
    I upload my Keil project file for your reference.
    By the way, there is no source file in the file, but only the project. Did you just give it to me for reference?
