08-17-2023 11:02 AM - edited 08-17-2023 11:04 AM
Hello, BOSCH
I am sending you an email because I have an inquiry during the test regarding the library.
If you compare the files you used among the links you sent me last time
It is estimated that the actual version used is "BSEC_1.4.8.0_Generic_Release_updated_v3".
(The internal sauce is being modified a little, so it's not completely the same.)
2. List of files currently using armcc in the compiler (Keil MDK-ARM)
At the time of the last test, I accidentally tested the BME680 without connecting it, so I thought there was no problem,
I connected the BME680 and tested it again, and it no longer progressed in the bsec_init(); below.
08-22-2023 09:08 AM
The sauce used for gcc is as follows
However, in the above list, libalgobsec.a is not available in armcc
Instead of the file, you use the in the path (BSEC_1.4.8.0_Generic_Release_updated_v3)(algo)(normal)(bin)(armcc)(Cortex_M0+)
It's not progressing.
Is the problem caused by using the file from the gcc source?
09-11-2023 04:59 AM
Hi mgchoi,
Because I used STM32F4 and Keil MDK-ARM compiler, so I used BSEC library "BSEC_1.4.8.0_Generic_Release\algo\normal_version\bin\armcc\Cortex_M4F\libalgobsec.lib".
Which MCU you used? You can select BSEC library according your host MCU architecture and compiler you used.
