11-02-2023 11:30 PM
I have a BME680 sensor interfaced using I2C to a Beaglebone Black SBC. It's functioning OK but I'm confused by what the 'gas heater' does.
I guess that the heater is to get the air quality measurements going but does it also affect the temperature and humidity readings?
I'm using the bme680 package from PyPi installed using pip.
Running this it goes into 'polling' mode and I see results like:-
13.79 C,967.85 hPa,66.97 %RH,71721.47698855039 Ohms
13.81 C,967.82 hPa,66.79 %RH,72968.57114389726 Ohms
13.84 C,967.82 hPa,66.63 %RH,74385.16382217684 Ohms
13.86 C,967.83 hPa,66.49 %RH,75403.50410127621 Ohms
13.88 C,967.83 hPa,66.33 %RH,77186.67437330067 Ohms
13.90 C,967.82 hPa,66.20 %RH,79198.32071358454 Ohms
13.93 C,967.81 hPa,66.05 %RH,79989.06250915483 Ohms
13.95 C,967.80 hPa,65.92 %RH,81618.88174279875 Ohms
13.97 C,967.80 hPa,65.80 %RH,82458.95418813737 Ohms
13.99 C,967.80 hPa,65.70 %RH,83712.21745256371 Ohms
14.01 C,967.81 hPa,65.60 %RH,84922.25079223014 Ohms
14.03 C,967.82 hPa,65.49 %RH,85999.60147520891 Ohms
14.05 C,967.84 hPa,65.39 %RH,87190.81907805824 Ohms
14.07 C,967.84 hPa,65.31 %RH,88326.88348620672 Ohms
14.09 C,967.84 hPa,65.21 %RH,89949.6685169239 Ohms
14.11 C,967.84 hPa,65.10 %RH,90411.07882563051 Ohms
14.13 C,967.85 hPa,65.03 %RH,91443.03457762799 Ohms
14.15 C,967.85 hPa,64.94 %RH,92305.04944738351 Ohms
14.16 C,967.85 hPa,64.86 %RH,95788.54299375357 Ohms
14.18 C,967.81 hPa,64.77 %RH,97001.04988745697 Ohms
14.20 C,967.82 hPa,64.69 %RH,98080.63309875103 Ohms
14.22 C,967.82 hPa,64.63 %RH,98906.22345883874 Ohms
14.23 C,967.82 hPa,64.56 %RH,100085.67844386413 Ohms
14.25 C,967.86 hPa,64.47 %RH,101997.027371513 Ohms
14.26 C,967.87 hPa,64.40 %RH,102950.26596207068 Ohms
14.28 C,967.85 hPa,64.33 %RH,103433.59820529057 Ohms
14.29 C,967.86 hPa,64.28 %RH,104167.16629089943 Ohms
It looks as if it's simply getting warmer and warmer, the temperature isn't really rising lake that, so what's going on?
I can't attach the python code I'm running so it's here.....
#!/usr/bin/env python3
import bme680
import time
print("""read-all.py - Displays temperature, pressure, humidity, and gas.
Press Ctrl+C to exit!
try:
sensor = bme680.BME680(bme680.I2C_ADDR_PRIMARY)
except (RuntimeError, IOError):
sensor = bme680.BME680(bme680.I2C_ADDR_SECONDARY)
# These calibration data can safely be commented
# out, if desired.
print('Calibration data:')
for name in dir(sensor.calibration_data):
if not name.startswith('_'):
value = getattr(sensor.calibration_data, name)
if isinstance(value, int):
print('{}: {}'.format(name, value))
# These oversampling settings can be tweaked to
# change the balance between accuracy and noise in
# the data.
sensor.set_humidity_oversample(bme680.OS_2X)
sensor.set_pressure_oversample(bme680.OS_4X)
sensor.set_temperature_oversample(bme680.OS_8X)
sensor.set_filter(bme680.FILTER_SIZE_3)
sensor.set_gas_status(bme680.ENABLE_GAS_MEAS)
print('\n\nInitial reading:')
for name in dir(sensor.data):
value = getattr(sensor.data, name)
sensor.set_gas_heater_temperature(320)
sensor.set_gas_heater_duration(150)
sensor.select_gas_heater_profile(0)
# Up to 10 heater profiles can be configured, each
# with their own temperature and duration.
# sensor.set_gas_heater_profile(200, 150, nb_profile=1)
# sensor.select_gas_heater_profile(1)
print('\n\nPolling:')
try:
while True:
if sensor.get_sensor_data():
output = '{0:.2f} C,{1:.2f} hPa,{2:.2f} %RH'.format(
sensor.data.temperature,
sensor.data.pressure,
sensor.data.humidity)
if sensor.data.heat_stable:
print('{0},{1} Ohms'.format(
output,
sensor.data.gas_resistance))
else:
print(output)
time.sleep(1)
except KeyboardInterrupt:
pass
11-07-2023 08:06 AM
Hi chrisisbd,
Have you not used BSEC for your air quality measurement?
11-07-2023 08:56 AM
No! 🙂 The main reason that I'm using a BME680 is that I couldn't find a BME280 breakout board that allowed setting the address to the non-default 0x77 and ran from 5v. Thus my basic use for the BME680 is simply to read Temperature, Humidity and Pressure. I need two sensors, one for 'indoors' and one for 'outdoors'. I have a BME280 at the default address of 0x76 and, as I said I can't find a board for another BME280 which runs on 5v and can be changed to 0x77.
The BME680 board I have is for 5v (i.e. there's a regulator producing 3.3v for the BME680) and it's easy to switch it to 0x77.
If I simply don't activate the heater is the BME680 pretty similar to a BME280 functionally?
11-09-2023 11:28 PM
Hi @chrisisbd,
Yes, you are right.
BME680 is BME280 + VOC sensor.
Therefore, if you don't use VOC, BME680 is pretty much same as BME280.
Let us know if you have any questions.
