10-11-2023 10:02 AM
I am testing the BME680 sensor with BSEC library. In "regular" conditions the output for humidity and temperature seems kind of reasonable, but when I put it in a sealed plastic container, this is what happens (yellow line marks the change):
How can it be that in a sealed, small container, the humidity starts to increase? I can understand that the temperature changes since the heat has nowhere to go, but humidity?
11-30-2023 10:36 AM
Hi tomjones,
Could you help give feedback to us? Thanks.
11-30-2023 03:21 PM
i use BSEC 1.8.1492. I only have one sensor so unfortunately can't compare the results. Once the sensor is out, it does return to normal.
12-01-2023 02:18 AM
Hi tomjones,
What do you mean "Once the sensor is out, it does return to normal."?
12-05-2023 05:39 PM
i mean once it is out of the container. Anyways, i doubtwe will find any answer to this so i close the discussion.
