    BME680 bsec_config_iaq
    Hello Bosch,
    would it be possible to describe the structure of the uint8_t bsec_config_iaq ?
    I think (as far as I understood) here are the register definitions, regarding the datasheet, inside.
    If somebody would like to modify a register setting (as sample for using in an extended temperature range) he could make an own config file, even for some "experiments".
    I still think that this is related to my other issue using the sensor outside - see
    https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BME680-strange-outside-values/m-p/7194#M...
    Michael
    Tags (2)
    Re: BME680 bsec_config_iaq
    Hi Michael,
    the bsec_config_iaq is an encrypted string that cannot be modified by the end user. We validate the entire use-case in the lab and in the field for certain configurations, then release the appropriate configuration strings. If you have different requirements you can contact Bosch Sensortec technical support right here on this forum.
