    BME680 bsec library with Arduino IDE uses delay()?!?!?
    mgchristensen
    Use of delay() in Arduino code is universally considered bad practice.  The better approach is to test a duration in millis.
    Looking at the code in the provided libraries in BSEC_Arduino_Library, I note, in bsec.cpp, the function void Bsec::delay_us(uint32_t period, void *intfPtr).  This function uses delay().  The use of delay() in bsec.cpp interferes with the timing of code in loop() if a call is made to the run() method.
    Has anyone reimplemented bsec.cpp to avoid use of delay()?  I plan on doing so, but do not want to "reinvent the wheel" if I can avoid that.
    Thanks to all in advance.
    Hi mgchristensen,
    In bsec.cpp, the delay_us() function has been adapted to the millisecond delay to microsecond delay of the delay() function.
    @brief Task that delays for a us period of time
    (void) intfPtr;
    // Wait for a period amount of ms
    // The system may simply idle, sleep or even perform background tasks
    delay(period/1000);
    Thank you for your reply!  I clicked accept as solution in error, and my reply was dumped into the bit bucket.
    The line delay(period/1000); is precisely what the problem is.  I will post again with a better explanation.
