06-25-2023 10:01 AM
Hey,
i've created a model with BME AI-Studio from the coffee example. I now want to deploy this model through the basic_config_state.ino file by replacing the line
06-26-2023 09:23 AM
Hi faulehenne,
You can download latest BSEC2.4.0.0 package from https://www.bosch-sensortec.com/software-tools/software/bme688-software
There is Arduino example project under folder "BSEC2.4.0.0_Generic_Release_23012023\examples\BSEC_Integration_Examples\examples\bsec_iot_example" for your reference.
After you train data and export config file in BME AI-Studio, to deploy config file to BME688 dev kit, you could copy .aiconfig and .config files to SD card; to deploy config file to Arduino software, you could replace your config file(.c, .h) to "BSEC2.4.0.0_Generic_Release_23012023\examples\BSEC_Integration_Examples\src\config\Selectivity_Config.c" and "BSEC2.4.0.0_Generic_Release_23012023\examples\BSEC_Integration_Examples\src\config\Selectivity_Config.h".
07-29-2023 05:19 PM
i copied my .aiconfig and config files to the SD card. After replacing the Selectivity_Config.h and Selectivity_Config.c with my files and copying them to the examples directory as well as copying the bsec_interfaces.h and bsec_datatypes.h to the example directory the compiling still fails.
The file that i created with AI Studio includes a file called bsec_serialized_configurations_selectivity.h which can not be found in the whole directory. After finding one in an older release and importing it - the compiling still fails with the compilation error
"Selectivity_config" was not declared in this scope (line 262 of bsec_iot_example.ino)
I've tried multiple ways of finding the file in fresher releases.
08-17-2023 10:59 AM
Hi faulehenne,
If you cannot find the file during compilation, you need to check if your compilation environment contains the correct path and includes the file to be compiled in the code.
