Using the BSEC2 library and the 'basic' example, I'm noticing that when reading values of
BSEC_OUTPUT_STATIC_IAQ and BSEC_OUTPUT_CO2_EQUIVALENT
that the value of co2 equivalent seems to be 10 times time the value of static IAQ
Is this an expected result?
Do you mean that CO2 value is 10 times larger than static IAQ?
No, CO2 and static IAQ are not directly correlated it.
Please let me know if you have further questions.
It must be a co-incidence. Observation is that for higher values, there is the impression of a relationship.
