08-02-2022 02:38 PM
As already mentioned by my collegues, the BME688 Sequential mode is not detailed in the latest BME688 Datasheet (BME68X_ODR3_MSK/Apr2021)
My first question would be -- is there a modified Datasheet that does describe this mode?
Otherwise, I would like to understand the timing of this mode. After reverse engineering the Sequential mode demo code, I see that the mode field in reg Ctrl_meas gets the value 3 to select Sequential mode. Furthermore, there are 2 additional fields that specify a so-called "sleep duration during Sequential mode" -- which I don't fully understand. I see that this sleep-duration (saved as odr field in a memory structure) is saved in 2 bit fields (odr20 & odr3) in registers 0x75 and 0x71 respectuflly. The odr bit combinations map to delay times as follows:
08-08-2022 03:59 PM
Hi amitr,
Currently, BME688 sequential mode timing was not open in document. We need to check whether we will open it in the future.
08-12-2022 09:46 AM
Hi amitr,
Could we know detailed information about your application?
08-24-2022 08:11 AM
Hi amitr,
Could you give feedback to us? Thanks.
09-08-2022 07:40 AM
Since there was no feedback for a long time, we close this topic first. You could update feedback in the future if you have.
