    BME688 service life
    BME688 service life
    Pai
    Hi
    The conditions are as follows:
    1. BME688 uses parallel mode
    2. Set 10 points, which are consistent with example (parallel_mode.c):
           /* Heater temperature in degree Celsius */
           uint16_t temp_prof[10] = { 320, 100, 100, 100, 200, 200, 200, 320, 320, 320 };
           /* Multiplier to the shared heater duration */
           uint16_t mul_prof[10] = { 5, 2, 10, 30, 5, 5, 5, 5, 5, 5 };
    3. Continuous sampling multiple times, no sleep
    Problems
    1) When the heating temperature is 100 ℃, the resistance value will reach the peak of 102400000 ohms (gas_range and gas_res_adc are both 0)
    2) After testing for about a month, the sensor has no reaction to some gases
    wonder:
    1) Is it caused by no sleep in each test?
    2) Does not sleep affect sensor life?
    3) What conditions will affect the life of the sensor: for example, the selection of parallel mode or force mode, the selection of heating temperature, gas concentration, or the above mentioned sleep?
    Thank you for your answer
    Hi zrummler,
    You can refer to previous comments.
