08-14-2023 09:49 PM
I want to use Int2 as un latched, 0v = Interrupt, input. I set x49 = '04', which sets Int2 to a level value, and x54 = '0A', which is 'active low', 'open drain', 'output disabled, 'input enabled'. I attach Vdd through a pull up resistor to Int2, and then connect Int2 to ground to trigger an interrupt. This method should be applying a constant '0v' =Interrupt, but via development desktop I see intermittent '0's', which suggests that the interrupt is constantly being reset every time it is triggered low. Am I missing something in the interrupt setup? What I want, and should see is "Int2"=0 as long as I am applying 0v/ground to the interrupt pin.
11-28-2023 08:14 AM
Hi Swingpro,
Do you want to add tag in BMI270 for synchronization among sensor data by external interrupt signal? If yes, we can provide example to you.
