    BMI270 FIFO acc gyr aux frame count not match
    HMK
    I try the code from below link to use fifo watermark header mode.
    https://github.com/boschsensortec/BMI270-Sensor-API/blob/master/bmi270_examples/aux_fifo_watermark_h...
    I got  data.  My watermark level is 650. I expect got around 30 frame for each sensor, and each sensor's frame count should be equal. But actually frame count I got is like below:
    The acc frame count is less than gyro and aux.
    Could please help?
    Yang
    4 REPLIES 4
    Hi HMK,
    You can refer to attached example code. If you used application board 3.0+BMI270 shuttle board 3.0 and run the code in COINES environement, you should run the code in RAM or Flash.
    mingw32-make LOCATION=RAM TARGET=MCU_APP30 download
    mingw32-make LOCATION=FLASH TARGET=MCU_APP30 download
    We don't have COINES board and the  environement.  It seems we got the dummy bytes. How to avoid this?
    Yang
    We also tried the headless mode. Got same result.
    The return value of below code is  BMI2_W_DUMMY_BYTE.
    rslt = check_dummy_frame(BMI2_FIFO_HEADERLESS_DUMMY_ACC, &data_index, skip_length, fifo);
    Hi HMK,
    You can check the length of your FIFO and whether the data read is an integer multiple of the data per frame.
