    BMI088 initialization failed, SensorAPI, Coines
    Greg_
    Hello! I have App board 3.0 with BMI088 shuttle board
    I'm trying to run BMI08x_SensorAPI/examples/bmi08x/read_sensor_data example from GitHub
    App log:
    Shuttle ID is 0x66
    I2C Interface
    Accel chip_id: 0x1e
    bmi08g_init Error [-2] : Communication failure
    init_bmi08 Error [-2] : Communication failure
    bmi08g_set_int_config Error [-2] : Communication failure
    bmi08g_get_regs Error [-2] : Communication failure
    enable_bmi08_interrupt Error [-2] : Communication failure
    disable_bmi08_interrupt Error [-2] : Communication failure
    I did some digging with gdb and found that the initial error code is -10 and comes from:
    dev->intf_rslt = dev->read(reg_addr, reg_data, len, dev->intf_ptr_gyro);
    from static int8_t get_regs(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, struct bmi08_dev *dev)
    from bmi08g.c
    How to solve this issue?
    Regards, Greg
    ashnichloe67
    Hey there,
    If you want to resolve this issue, you first need to make sure you check:
     Ensure all wires are securely connected.
    Verify the I2C address in your code matches the BMI088's.
    Power Supply: Make sure the board is properly powered.
    Check if the I2C lines have the correct pull-up resistors.
     Double-check the sensor initialization sequence in your code.
    Thank you for your reply. Here's an update on my progress:
    I am using an Application Board 3.0 with a Shuttle Board 3.0 and I believe that the wiring is correct, and all resistors are in the right places.
    The sample code I am using can be found here:
    I have tested both the primary and secondary I2C addresses without success. Only the accelerometer responds, as I mentioned before ("Accel chip_id: 0x1e" in a log).
    I suspect that the issue is not with the hardware or wiring, but with the initialization sequence. I hope someone can provide me with guidance towards a solution.
    Regards, Greg
    Hi Greg_,
    You can capture I2C waveform by logic analyzer and see what what happened on the bus?
