04-09-2023 03:13 PM
I am trying to get accelerometer readings from bmi270 imu sensor but am unable to initialize the sensor according to the provided data sheet.
after going through the initialization process the sensor returns an error
Can anyone help me where I am going wrong ?
#include <SPI.h>
#define BEEPER_1 PC5
#define MOTOR_1 PB6
#define MOTOR_2 PB7
#define MOTOR_3 PB8
#define MOTOR_4 PB9
#define MOTOR_5 PB0
#define MOTOR_6 PB1
#define MOTOR_7 PB5
#define MOTOR_8 PB4
#define SERVO_1 PA8
#define PPM_1 PA3
#define LED_STRIP_1 PC9
#define Serial_TX_1 PA9
#define Serial_TX_2 PA2
#define Serial_TX_3 PC10
#define Serial_TX_4 PA0
#define Serial_TX_5 PC12
#define Serial_TX_6 PC6
#define Serial_RX_1 PA10
#define Serial_RX_2 PA3
#define Serial_RX_3 PC11
#define Serial_RX_4 PA1
#define Serial_RX_5 PD2
#define Serial_RX_6 PC7
#define I2C_SCL_2 PB10
#define I2C_SDA_2 PB11
#define LED_1 PC8
#define SPI_SCK_1 PA5
#define SPI_SCK_2 PB13
#define SPI_MISO_1 PA6
#define SPI_MISO_2 PB14
#define SPI_MOSI_1 PA7
#define SPI_MOSI_2 PB15
#define CAMERA_CONTROL_1 PB3
#define ADC_BATT_1 PC0
#define ADC_RSSI_1 PC2
#define ADC_CURR_1 PC1
#define SDCARD_CS_1 PA15
#define PINIO_1 PC3 // used for disabling bluetooth module
#define OSD_CS_1 PB12
#define GYRO_EXTI_1 PC4
#define GYRO_CS_1 PA4
SPIClass SPI_1(SPI_MOSI_1, SPI_MISO_1, SPI_SCK_1);
//HardwareSerial Serial(Serial_RX_6, Serial_TX_6);
uint16_t accx = 0;
const uint8_t bmi270_legacy_config_file[] = {
0xc8, 0x2e, 0x00, 0x2e, 0x80, 0x2e, 0x3c, 0xb2, 0xc8, 0x2e, 0x00, 0x2e, 0x80, 0x2e, 0x9b, 0x03, 0x80, 0x2e, 0xa4,
0xb3, 0x80, 0x2e, 0xb8, 0x03, 0xc8, 0x2e, 0x00, 0x2e, 0x80, 0x2e, 0xc4, 0xb2, 0x50, 0x30, 0x21, 0x2e, 0x59, 0xf5,
0x10, 0x30, 0x21, 0x2e, 0x4a, 0xf1, 0x21, 0x2e, 0x6a, 0xf5, 0x80, 0x2e, 0xe5, 0x01, 0x00, 0x5d, 0x01, 0x00, 0x22,
0x00, 0x77, 0x00, 0x00, 0x10, 0x00, 0x10, 0xd1, 0x00, 0x45, 0xf5, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1,
0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00,
0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e,
0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80,
0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1,
0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x45, 0x5a, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5d, 0x00, 0x00, 0x88, 0x00, 0x05, 0xe0, 0xaa, 0x38, 0x05, 0xe0, 0x90,
0x30, 0x00, 0x00, 0x30, 0x0a, 0x80, 0x40, 0x10, 0x27, 0xe8, 0x73, 0x04, 0x30, 0x00, 0x02, 0x00, 0x01, 0x00, 0x30,
0x10, 0x0b, 0x09, 0x08, 0xfa, 0x00, 0x96, 0x00, 0x4b, 0x09, 0x11, 0x00, 0x11, 0x00, 0x02, 0x00, 0x00, 0x00, 0x22,
0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x06, 0x00, 0x09, 0x00,
0x82, 0x00, 0x06, 0x00, 0x06, 0x00, 0x08, 0x00, 0x50, 0x00, 0x00, 0x00, 0x4c, 0x04, 0x02, 0x00, 0x03, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x32, 0x01, 0xe6, 0x78, 0x84, 0x00, 0x9c, 0x6c,
0x07, 0x00, 0x64, 0x75, 0xaa, 0x7e, 0x5f, 0x05, 0xbe, 0x0a, 0x5f, 0x05, 0x96, 0xe8, 0xef, 0x41, 0x01, 0x00, 0x0c,
0x00, 0x0c, 0x00, 0x4a, 0x00, 0xa0, 0x00, 0x00, 0x00, 0x0c, 0x00, 0xf0, 0x3c, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x9a, 0x00, 0x9a,
0x01, 0x9f, 0x01, 0x88, 0x01, 0x96, 0x01, 0x84, 0x01, 0x00, 0x0c, 0xff, 0x0f, 0x00, 0x04, 0xc0, 0x00, 0x5b, 0xf5,
0x98, 0xf1, 0x7b, 0x01, 0x7a, 0x01, 0x1e, 0xf2, 0xfd, 0xf5, 0xfc, 0xf5, 0x76, 0x01, 0x7e, 0x01, 0x80, 0x00, 0xa0,
0x00, 0x5f, 0xff, 0xc8, 0x00, 0xcb, 0x00, 0xcb, 0x00, 0xd2, 0x00, 0x81, 0x01, 0x69, 0xf5, 0xe0, 0x00, 0x3f, 0xff,
0x19, 0xf4, 0x58, 0xf5, 0x66, 0xf5, 0xff, 0x00, 0x64, 0xf5, 0xc0, 0xf1, 0xba, 0xf1, 0xae, 0xf1, 0xa0, 0x00, 0xdf,
0x00, 0xa2, 0x01, 0xfa, 0x00, 0xfc, 0x00, 0xff, 0x3f, 0xff, 0xfb, 0x00, 0x38, 0x00, 0x30, 0xb3, 0x01, 0xba, 0x01,
0xbc, 0x01, 0xc2, 0x01, 0xca, 0x01, 0xff, 0x7f, 0xff, 0x01, 0x8e, 0x01, 0x74, 0xf7, 0x00, 0x40, 0x5f, 0x0f, 0xeb,
0x00, 0x7f, 0xff, 0xc2, 0xf5, 0x68, 0xf7, 0x59, 0x0f, 0x4d, 0x0f, 0x53, 0x0f, 0x72, 0x0f, 0x58, 0xf7, 0x5b, 0xf7,
0x75, 0x0f, 0x00, 0x80, 0x86, 0x00, 0x64, 0x0f, 0x77, 0x0f, 0xb3, 0xf1, 0x71, 0x0f, 0x6c, 0xf7, 0xb9, 0xf1, 0xc6,
0xf1, 0x00, 0xe0, 0x00, 0xff, 0xd1, 0xf5, 0x79, 0x0f, 0x7c, 0x0f, 0xff, 0x03, 0x00, 0xfc, 0xf0, 0x3f, 0x8b, 0x00,
0x90, 0x00, 0x95, 0x00, 0x92, 0x00, 0x98, 0x00, 0x8d, 0x00, 0xa2, 0x00, 0xb9, 0x00, 0x2d, 0xf5, 0xca, 0xf5, 0x7c,
0x01, 0x20, 0xf2, 0xdb, 0x01, 0x00, 0x08, 0x00, 0xf8, 0xe8, 0x03, 0x01, 0x80, 0xb8, 0x7e, 0xe1, 0x7a, 0xf0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xa9, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x1a, 0x24, 0x22, 0x00, 0x80, 0x2e, 0x00, 0xb0, 0x1d, 0x52, 0x00, 0x2e, 0x60, 0x40, 0x41, 0x40, 0x0d, 0xbc,
0x98, 0xbc, 0xc0, 0x2e, 0x01, 0x0a, 0x0f, 0xb8, 0x1f, 0x52, 0x53, 0x3c, 0x52, 0x40, 0x40, 0x40, 0x4b, 0x00, 0x82,
0x16, 0x26, 0xb9, 0x01, 0xb8, 0x41, 0x40, 0x10, 0x08, 0x97, 0xb8, 0x01, 0x08, 0xc0, 0x2e, 0x11, 0x30, 0x01, 0x08,
0x43, 0x86, 0x25, 0x40, 0x04, 0x40, 0xd8, 0xbe, 0x2c, 0x0b, 0x22, 0x11, 0x54, 0x42, 0x03, 0x80, 0x4b, 0x0e, 0xf6,
0x2f, 0xb8, 0x2e, 0x21, 0x50, 0x10, 0x50, 0x23, 0x52, 0x05, 0x2e, 0xd5, 0x00, 0xfb, 0x7f, 0x00, 0x2e, 0x13, 0x40,
0x93, 0x42, 0x41, 0x0e, 0xfb, 0x2f, 0x98, 0x2e, 0x91, 0x03, 0x98, 0x2e, 0x87, 0xcf, 0x01, 0x2e, 0x70, 0x01, 0x00,
0xb2, 0xfb, 0x6f, 0x0b, 0x2f, 0x01, 0x2e, 0x69, 0xf7, 0xb1, 0x3f, 0x01, 0x08, 0x01, 0x30, 0xf0, 0x5f, 0x23, 0x2e,
0x70, 0x01, 0x21, 0x2e, 0x69, 0xf7, 0x80, 0x2e, 0x2e, 0x02, 0xf0, 0x5f, 0xb8, 0x2e, 0x03, 0x2e, 0xfc, 0xf5, 0x01,
0x2e, 0xc0, 0xf8, 0x25, 0x54, 0x27, 0x56, 0x82, 0x08, 0x0b, 0x2e, 0x69, 0xf7, 0xcb, 0x0a, 0x29, 0x58, 0x80, 0x90,
0xdd, 0xbe, 0x4c, 0x08, 0x5f, 0xb9, 0x59, 0x22, 0x80, 0x90, 0x07, 0x2f, 0x03, 0x34, 0xc3, 0x08, 0xf2, 0x3a, 0x0a,
0x08, 0x02, 0x35, 0xc0, 0x90, 0x4a, 0x0a, 0x48, 0x22, 0xc0, 0x2e, 0x23, 0x2e, 0xfc, 0xf5, 0x01, 0x2e, 0x7e, 0x01,
0x01, 0x8a, 0xf0, 0x50, 0x50, 0x41, 0x1a, 0x25, 0x03, 0xbd, 0x71, 0x82, 0x02, 0xbe, 0x2f, 0xb9, 0x42, 0x42, 0x81,
0xbd, 0x45, 0x41, 0x4f, 0xba, 0xf1, 0x7f, 0xbf, 0xb8, 0x0f, 0xb8, 0x5c, 0xb9, 0x24, 0x7f, 0x00, 0xb2, 0x31, 0x7f,
0xeb, 0x7f, 0xd2, 0x7f, 0x08, 0x2f, 0x10, 0x6f, 0x00, 0x90, 0x0b, 0x2f, 0x20, 0x6f, 0x00, 0x90, 0x08, 0x2f, 0x30,
0x6f, 0x00, 0x90, 0x05, 0x2f, 0x01, 0x30, 0x23, 0x2e, 0x7d, 0x00, 0xd0, 0x6f, 0x98, 0x2e, 0x95, 0xcf, 0x05, 0x2e,
0x7d, 0x00, 0x80, 0x90, 0x00, 0x30, 0x2b, 0x52, 0x2f, 0x56, 0x07, 0x2f, 0x2b, 0x58, 0x00, 0x2e, 0x10, 0x43, 0x63,
0x0e, 0xfc, 0x2f, 0x81, 0x84, 0x25, 0x2e, 0x7d, 0x00, 0x09, 0x2e, 0x7e, 0x01, 0x02, 0x85, 0x13, 0x41, 0x04, 0x41,
0xb1, 0xbd, 0xb1, 0xb9, 0x44, 0xbe, 0x82, 0x40, 0x44, 0xba, 0x24, 0xbd, 0xb3, 0x7f, 0x5c, 0x05, 0x24, 0xb9, 0x01,
0x56, 0x2d, 0x58, 0x92, 0x7f, 0xa5, 0x7f, 0x80, 0x7f, 0xc0, 0x7f, 0x73, 0x7f, 0x64, 0x7f, 0x00, 0x2e, 0xf2, 0x6f,
0x40, 0x7f, 0x51, 0x7f, 0x00, 0x2e, 0x90, 0x40, 0xf2, 0x7f, 0x00, 0x90, 0x04, 0x2f, 0x51, 0x6f, 0x00, 0x30, 0x40,
0x42, 0x45, 0x2c, 0x62, 0x6f, 0xc1, 0x40, 0x98, 0x2e, 0x74, 0xc0, 0x51, 0x6f, 0x00, 0x2e, 0x43, 0x40, 0xc0, 0xb2,
0x2d, 0x2f, 0x62, 0x6f, 0xa5, 0x6f, 0x84, 0x40, 0xc5, 0x0e, 0x07, 0x2f, 0x75, 0x6f, 0x10, 0x30, 0x45, 0x41, 0x40,
0xa1, 0x05, 0x30, 0x05, 0x22, 0x20, 0x1a, 0x02, 0x2f, 0x00, 0x30, 0x40, 0x42, 0x2c, 0x2d, 0x10, 0x30, 0x18, 0x28,
0x93, 0x6f, 0x40, 0x42, 0xc3, 0x0e, 0x25, 0x2f, 0xc0, 0x6f, 0x00, 0x90, 0x22, 0x2f, 0x45, 0x6f, 0x10, 0x30, 0xc5,
0x14, 0x46, 0xbf, 0xb3, 0xbf, 0xb7, 0x0b, 0x2b, 0x58, 0x65, 0x01, 0x2f, 0x5e, 0x0b, 0x30, 0x25, 0x1a, 0x00, 0x2f,
0x0b, 0x43, 0x01, 0x89, 0x2d, 0x2e, 0x79, 0x01, 0x67, 0x0e, 0xf7, 0x2f, 0x80, 0x7f, 0xc3, 0x7f, 0x0e, 0x2d, 0xb2,
0x6f, 0xc2, 0x0e, 0x08, 0x2f, 0x10, 0x30, 0x40, 0x42, 0x02, 0x30, 0x74, 0x6f, 0x63, 0x6f, 0x04, 0x41, 0x00, 0xa1,
0x02, 0x22, 0xc0, 0x42, 0x00, 0x2e, 0x62, 0x6f, 0x40, 0x6f, 0x73, 0x6f, 0x01, 0x80, 0xc1, 0x86, 0x81, 0x84, 0x41,
0x82, 0x03, 0xa2, 0x62, 0x7f, 0x73, 0x7f, 0xa4, 0x2f, 0xeb, 0x6f, 0xd0, 0x6f, 0x81, 0x6f, 0x10, 0x5f, 0x80, 0x2e,
0x95, 0xcf, 0x03, 0x2e, 0x7f, 0x01, 0x41, 0x84, 0x50, 0x50, 0x90, 0x40, 0x82, 0x40, 0x83, 0xbd, 0xbf, 0xb9, 0x2c,
0xba, 0xfb, 0x7f, 0xc0, 0xb2, 0xe4, 0x7f, 0x0b, 0x30, 0x36, 0x2f, 0x07, 0x2e, 0x7e, 0x00, 0xc0, 0x90, 0x04, 0x2f,
0xc1, 0x86, 0x27, 0x2e, 0x7e, 0x00, 0x37, 0x2e, 0x7f, 0x00, 0xa4, 0xbd, 0x04, 0xbd, 0x34, 0xb8, 0x41, 0x40, 0x91,
0xbc, 0x91, 0xb9, 0xb3, 0x7f, 0x24, 0xb9, 0x09, 0x52, 0xc0, 0x7f, 0xd2, 0x7f, 0x98, 0x2e, 0xb3, 0xc0, 0xd1, 0x6f,
0xb2, 0x6f, 0x51, 0x28, 0x41, 0x0f, 0x11, 0x30, 0x0d, 0x2f, 0xc2, 0x0e, 0x07, 0x2e, 0x7f, 0x00, 0x19, 0x28, 0x04,
0x2f, 0xc0, 0xa6, 0x04, 0x2f, 0x21, 0x2e, 0x7f, 0x00, 0x02, 0x2d, 0x21, 0x2e, 0x7f, 0x00, 0x04, 0x2c, 0x02, 0x30,
0x02, 0x30, 0x25, 0x2e, 0x7f, 0x00, 0xc0, 0x6f, 0x07, 0x2e, 0x7f, 0x00, 0x58, 0x0f, 0xfb, 0x6f, 0xe0, 0x6f, 0xb0,
0x5f, 0x4a, 0x22, 0x80, 0x2e, 0x95, 0xcf, 0xe0, 0x6f, 0x01, 0x30, 0x98, 0x2e, 0x95, 0xcf, 0x00, 0x30, 0x21, 0x2e,
0x7e, 0x00, 0xfb, 0x6f, 0xb0, 0x5f, 0xb8, 0x2e, 0x21, 0x2e, 0x59, 0xf5, 0x10, 0x30, 0xc0, 0x2e, 0x21, 0x2e, 0x4a,
0xf1, 0x80, 0x2e, 0x00, 0xc1, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9a, 0x01,
0x34, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0x2e, 0xd5, 0x00, 0x16, 0xb8, 0x02, 0x34, 0x4a, 0x0c, 0x21, 0x2e, 0x2d, 0xf5, 0xc0, 0x2e, 0x23,
0x2e, 0xd5, 0x00, 0x20, 0x50, 0xf6, 0x7f, 0xe7, 0x7f, 0x00, 0x2e, 0x35, 0x5c, 0x00, 0x2e, 0x87, 0x41, 0xff, 0xbf,
0xff, 0xbb, 0xc0, 0x91, 0x02, 0x2f, 0x37, 0x30, 0x2f, 0x2e, 0x69, 0xf5, 0xb8, 0x8f, 0x06, 0x32, 0xc7, 0x41, 0xfe,
0x09, 0xc0, 0xb3, 0x04, 0x2f, 0x17, 0x30, 0x2f, 0x2e, 0x95, 0x01, 0x2d, 0x2e, 0x61, 0xf5, 0xf6, 0x6f, 0xe7, 0x6f,
0xe0, 0x5f, 0xc8, 0x2e, 0x30, 0x50, 0xe5, 0x7f, 0xf6, 0x7f, 0xd7, 0x7f, 0x00, 0x2e, 0x35, 0x5a, 0x00, 0x2e, 0x46,
0x41, 0x6f, 0xbf, 0x6f, 0xbb, 0x80, 0x91, 0x02, 0x2f, 0x36, 0x30, 0x2d, 0x2e, 0x69, 0xf5, 0x46, 0x30, 0x0f, 0x2e,
0xa4, 0xf1, 0xbe, 0x09, 0x77, 0x8b, 0x80, 0xb3, 0x06, 0x2f, 0x0d, 0x2e, 0x6b, 0x01, 0x84, 0xaf, 0x02, 0x2f, 0x16,
0x30, 0x2d, 0x2e, 0xde, 0x00, 0x86, 0x30, 0x46, 0x43, 0x00, 0x2e, 0xf6, 0x6f, 0xe5, 0x6f, 0xd7, 0x6f, 0xd0, 0x5f,
0xc8, 0x2e, 0x10, 0x50, 0xfb, 0x7f, 0x98, 0x2e, 0x56, 0xc7, 0x98, 0x2e, 0x49, 0xc3, 0x02, 0x30, 0x30, 0x30, 0x11,
0x30, 0xfb, 0x6f, 0xf0, 0x5f, 0x25, 0x2e, 0x7e, 0x00, 0x25, 0x2e, 0xce, 0x00, 0x21, 0x2e, 0xdf, 0x00, 0x23, 0x2e,
0x7c, 0x00, 0x23, 0x2e, 0xfe, 0x00, 0x21, 0x2e, 0x78, 0x01, 0xb8, 0x2e, 0x11, 0x30, 0x81, 0x08, 0x01, 0x2e, 0x6a,
0xf7, 0x71, 0x3f, 0x23, 0xbd, 0x01, 0x08, 0x02, 0x0a, 0xc0, 0x2e, 0x21, 0x2e, 0x6a, 0xf7, 0x40, 0x50, 0x98, 0x2e,
0xbd, 0x0e, 0x50, 0x32, 0x98, 0x2e, 0x48, 0x03, 0x00, 0x30, 0xf0, 0x7f, 0xe0, 0x7f, 0x21, 0x2e, 0x69, 0xf5, 0x00,
0x2e, 0x00, 0x2e, 0xd0, 0x2e, 0x00, 0x2e, 0x01, 0x80, 0x08, 0xa2, 0xfb, 0x2f, 0x05, 0x2e, 0xa8, 0x00, 0x2f, 0xbc,
0xae, 0xbc, 0xad, 0xbd, 0x0f, 0xb8, 0x9f, 0xb8, 0x01, 0x0a, 0x05, 0x2e, 0x93, 0x00, 0xbf, 0xb9, 0xaf, 0xb8, 0x03,
0x0a, 0x01, 0x0a, 0x21, 0x2e, 0x7a, 0x00, 0x98, 0x2e, 0xeb, 0xb5, 0x03, 0x2e, 0x9d, 0x01, 0x21, 0x2e, 0x7b, 0x00,
0x40, 0xb2, 0x1a, 0x2f, 0x05, 0x2e, 0x8a, 0x00, 0x01, 0x52, 0x98, 0x2e, 0xc7, 0xc1, 0x03, 0x2e, 0xa8, 0x00, 0x9c,
0xbc, 0x9f, 0xb8, 0x23, 0x2e, 0xdd, 0x00, 0x40, 0x90, 0xf0, 0x7f, 0x03, 0x2f, 0x01, 0x52, 0x98, 0x2e, 0x4c, 0xb6,
0x03, 0x2d, 0x03, 0x52, 0x98, 0x2e, 0x4c, 0xb6, 0xe0, 0x7f, 0x98, 0x2e, 0x4b, 0x02, 0x10, 0x30, 0x21, 0x2e, 0x7c,
0x00, 0x01, 0x2e, 0x99, 0x01, 0x00, 0xb2, 0x07, 0x2f, 0x01, 0x2e, 0x7b, 0x00, 0x00, 0xb2, 0x03, 0x2f, 0x05, 0x50,
0x07, 0x52, 0x98, 0x2e, 0x07, 0xcc, 0x01, 0x2e, 0x87, 0x01, 0x00, 0xb2, 0x35, 0x2f, 0x05, 0x2e, 0x8a, 0x00, 0x09,
0x52, 0x98, 0x2e, 0xc7, 0xc1, 0x03, 0x2e, 0x93, 0x01, 0x40, 0xb2, 0xf0, 0x7f, 0x08, 0x2f, 0x01, 0x2e, 0x7b, 0x00,
0x00, 0xb2, 0x04, 0x2f, 0x00, 0x30, 0x21, 0x2e, 0x93, 0x01, 0x98, 0x2e, 0x88, 0xb5, 0x01, 0x2e, 0x79, 0x00, 0x00,
0xb2, 0x1e, 0x2f, 0x98, 0x2e, 0x78, 0xb4, 0x98, 0x2e, 0x49, 0xb5, 0x09, 0x50, 0x98, 0x2e, 0x4d, 0xc3, 0x09, 0x50,
0x98, 0x2e, 0x5a, 0xc7, 0x98, 0x2e, 0xf9, 0x02, 0x81, 0x3f, 0x01, 0x2e, 0x79, 0x01, 0x01, 0x08, 0x09, 0x52, 0xd0,
0x7f, 0x21, 0x2e, 0x79, 0x01, 0x98, 0x2e, 0xff, 0xc5, 0xd1, 0x6f, 0x08, 0x0a, 0x21, 0x2e, 0x79, 0x01, 0x98, 0x2e,
0xc3, 0xb1, 0x10, 0x30, 0x21, 0x2e, 0x7c, 0x00, 0x01, 0x2e, 0x95, 0x01, 0x00, 0xb2, 0x04, 0x2f, 0x98, 0x2e, 0x2e,
0x02, 0x00, 0x30, 0x21, 0x2e, 0x95, 0x01, 0x01, 0x2e, 0x6b, 0x01, 0x04, 0xae, 0x0b, 0x2f, 0x01, 0x2e, 0x87, 0x01,
0x00, 0xb2, 0x07, 0x2f, 0x09, 0x52, 0x98, 0x2e, 0x74, 0x0e, 0x00, 0xb2, 0x02, 0x2f, 0x10, 0x30, 0x21, 0x2e, 0xd7,
0x00, 0x01, 0x2e, 0xd7, 0x00, 0x00, 0x90, 0x90, 0x2e, 0x72, 0xb1, 0x01, 0x2e, 0x6e, 0x01, 0x00, 0xb2, 0x04, 0x2f,
0x98, 0x2e, 0x15, 0x0e, 0x00, 0x30, 0x21, 0x2e, 0xde, 0x00, 0x01, 0x2e, 0xde, 0x00, 0x00, 0xb2, 0x12, 0x2f, 0x01,
0x2e, 0x6b, 0x01, 0x00, 0x90, 0x02, 0x2f, 0x98, 0x2e, 0x05, 0x0e, 0x09, 0x2d, 0x98, 0x2e, 0x5d, 0x0d, 0x01, 0x2e,
0x6b, 0x01, 0x04, 0x90, 0x02, 0x2f, 0x50, 0x32, 0x98, 0x2e, 0x48, 0x03, 0x00, 0x30, 0x21, 0x2e, 0xde, 0x00, 0x01,
0x2e, 0xd6, 0x00, 0x00, 0xb2, 0x90, 0x2e, 0x8a, 0xb1, 0x01, 0x2e, 0xd6, 0x00, 0x01, 0x31, 0x01, 0x08, 0x00, 0xb2,
0x04, 0x2f, 0x98, 0x2e, 0x47, 0xcb, 0x10, 0x30, 0x21, 0x2e, 0x7c, 0x00, 0x81, 0x30, 0x01, 0x2e, 0xd6, 0x00, 0x01,
0x08, 0x00, 0xb2, 0x61, 0x2f, 0x03, 0x2e, 0x89, 0x00, 0x01, 0x2e, 0x6b, 0x01, 0x98, 0xbc, 0x98, 0xb8, 0x05, 0xb2,
0x13, 0x58, 0x23, 0x2f, 0x07, 0x90, 0x0d, 0x54, 0x00, 0x30, 0x37, 0x2f, 0x15, 0x41, 0x04, 0x41, 0xdc, 0xbe, 0x44,
0xbe, 0xdc, 0xba, 0x2c, 0x01, 0x61, 0x00, 0x13, 0x56, 0x4a, 0x0f, 0x0c, 0x2f, 0xd1, 0x42, 0x94, 0xb8, 0xc1, 0x42,
0x11, 0x30, 0x05, 0x2e, 0x6a, 0xf7, 0x2c, 0xbd, 0x2f, 0xb9, 0x80, 0xb2, 0x08, 0x22, 0x98, 0x2e, 0xf5, 0x03, 0x21,
0x2d, 0x61, 0x30, 0x23, 0x2e, 0x6b, 0x01, 0x98, 0x2e, 0xf5, 0x03, 0x00, 0x30, 0x21, 0x2e, 0x5a, 0xf5, 0x18, 0x2d,
0xd1, 0x7f, 0x50, 0x30, 0x98, 0x2e, 0x48, 0x03, 0x13, 0x52, 0x0b, 0x50, 0x50, 0x42, 0x70, 0x30, 0x11, 0x54, 0x42,
0x42, 0x7e, 0x82, 0xd2, 0x6f, 0x80, 0xb2, 0x42, 0x42, 0x05, 0x2f, 0x21, 0x2e, 0x6b, 0x01, 0x10, 0x30, 0x98, 0x2e,
0xf5, 0x03, 0x03, 0x2d, 0x60, 0x30, 0x21, 0x2e, 0x6b, 0x01, 0x01, 0x2e, 0x6b, 0x01, 0x06, 0x90, 0x18, 0x2f, 0x01,
0x2e, 0x78, 0x00, 0x0f, 0x54, 0x0b, 0x52, 0xd0, 0x7f, 0x98, 0x2e, 0x7a, 0xc1, 0xd1, 0x6f, 0x08, 0x1a, 0x40, 0x30,
0x08, 0x2f, 0x21, 0x2e, 0x6b, 0x01, 0x20, 0x30, 0x98, 0x2e, 0x24, 0xb6, 0x50, 0x32, 0x98, 0x2e, 0x48, 0x03, 0x05,
0x2d, 0x98, 0x2e, 0x1e, 0x0e, 0x00, 0x30, 0x21, 0x2e, 0x6b, 0x01, 0x41, 0x30, 0x01, 0x2e, 0xd6, 0x00, 0x01, 0x08,
0x00, 0xb2, 0x26, 0x2f, 0x01, 0x2e, 0x71, 0x01, 0x00, 0xb2, 0x0d, 0x2f, 0x01, 0x90, 0x1d, 0x2f, 0x05, 0x2e, 0xbf,
0x00, 0x07, 0x2e, 0x72, 0x01, 0xa1, 0x32, 0x17, 0x58, 0x98, 0x2e, 0xae, 0xb7, 0x00, 0x30, 0x21, 0x2e, 0x71, 0x01,
0x12, 0x2d, 0x15, 0x58, 0xa3, 0x32, 0x10, 0x41, 0x11, 0x41, 0x18, 0xb9, 0x04, 0x41, 0x98, 0xbc, 0x41, 0x0a, 0x94,
0x0a, 0x98, 0x2e, 0xa0, 0xb7, 0x11, 0x30, 0x21, 0x2e, 0x72, 0x01, 0x21, 0x2e, 0x7b, 0x01, 0x23, 0x2e, 0x71, 0x01,
0x10, 0x30, 0x21, 0x2e, 0x7c, 0x00, 0x00, 0x30, 0x21, 0x2e, 0xd6, 0x00, 0x18, 0x2d, 0x01, 0x2e, 0x6b, 0x01, 0x03,
0xaa, 0x01, 0x2f, 0x98, 0x2e, 0x2b, 0x0e, 0x01, 0x2e, 0x6b, 0x01, 0x3f, 0x80, 0x03, 0xa2, 0x01, 0x2f, 0x00, 0x2e,
0x02, 0x2d, 0x98, 0x2e, 0x41, 0x0e, 0x30, 0x30, 0x98, 0x2e, 0x38, 0xb6, 0x00, 0x30, 0x21, 0x2e, 0xd7, 0x00, 0x50,
0x32, 0x98, 0x2e, 0x48, 0x03, 0x01, 0x2e, 0x7c, 0x00, 0x00, 0xb2, 0x29, 0x2f, 0x98, 0x2e, 0xf5, 0xcb, 0x03, 0x2e,
0x6c, 0x01, 0x19, 0x54, 0x41, 0x0a, 0xbc, 0x84, 0x23, 0x2e, 0x7a, 0x01, 0x83, 0x80, 0x74, 0x30, 0x23, 0x40, 0x05,
0x40, 0x1b, 0x50, 0x81, 0x40, 0xdc, 0x08, 0x18, 0xb9, 0x11, 0x42, 0xd3, 0xbe, 0xe4, 0x6f, 0xc5, 0xbc, 0xdd, 0x0a,
0x12, 0x42, 0x59, 0x0a, 0x11, 0x42, 0xd0, 0x7f, 0xf1, 0x31, 0x00, 0x40, 0xf2, 0x6f, 0x25, 0xbd, 0x01, 0x08, 0x02,
0x0a, 0xc0, 0x7f, 0x98, 0x2e, 0xa8, 0xcf, 0x06, 0xbc, 0xc1, 0x6f, 0xd2, 0x6f, 0x08, 0x0a, 0x80, 0x42, 0x98, 0x2e,
0x0c, 0x02, 0x00, 0x30, 0x21, 0x2e, 0x9d, 0x01, 0x21, 0x2e, 0x99, 0x01, 0x21, 0x2e, 0x7c, 0x00, 0x21, 0x2e, 0x87,
0x01, 0x80, 0x2e, 0x09, 0xb0, 0x01, 0x2e, 0x80, 0x01, 0x01, 0x40, 0x90, 0x50, 0x9f, 0xbd, 0x13, 0xbd, 0xbf, 0xb9,
0x2c, 0xb9, 0xfb, 0x7f, 0xe2, 0x7f, 0xc0, 0xb2, 0x0b, 0x30, 0x62, 0x2f, 0x07, 0x2e, 0xce, 0x00, 0x31, 0x54, 0xc0,
0x90, 0x0b, 0x2f, 0x9b, 0x42, 0xc1, 0x86, 0x9b, 0x42, 0x27, 0x2e, 0xce, 0x00, 0x37, 0x2e, 0xcf, 0x00, 0x37, 0x2e,
0xd0, 0x00, 0x37, 0x2e, 0xd1, 0x00, 0x8b, 0x42, 0x01, 0x84, 0x17, 0xbc, 0x83, 0x40, 0x32, 0xbd, 0x99, 0xbc, 0x9a,
0xba, 0xba, 0xbd, 0x0e, 0xb8, 0x28, 0xb9, 0xba, 0xb9, 0x09, 0x58, 0x1a, 0x25, 0x0d, 0x2e, 0xcf, 0x00, 0x77, 0x82,
0x85, 0x7f, 0xa6, 0x7f, 0x74, 0x7f, 0x93, 0x7f, 0xd2, 0x7f, 0xc0, 0x7f, 0x98, 0x2e, 0xd1, 0xc3, 0x03, 0x2e, 0xcf,
0x00, 0x08, 0x1a, 0xb0, 0x7f, 0x01, 0x30, 0x01, 0x2f, 0x23, 0x2e, 0xd1, 0x00, 0x01, 0x2e, 0xd1, 0x00, 0xd1, 0x6f,
0x41, 0x0e, 0x14, 0x2f, 0xc1, 0x6f, 0x40, 0xb2, 0x0b, 0x2f, 0x43, 0xb2, 0x09, 0x2f, 0x09, 0x54, 0x31, 0x56, 0x98,
0x2e, 0x0b, 0xc4, 0x00, 0x90, 0x06, 0x2f, 0xb1, 0x6f, 0x23, 0x2e, 0xd0, 0x00, 0x03, 0x2d, 0xb1, 0x6f, 0x23, 0x2e,
0xd0, 0x00, 0xd1, 0x6f, 0x23, 0x2e, 0xd1, 0x00, 0x03, 0x2e, 0xd1, 0x00, 0x41, 0x82, 0x23, 0x2e, 0xd1, 0x00, 0x09,
0x50, 0x31, 0x52, 0x12, 0x40, 0x52, 0x42, 0x00, 0x2e, 0x12, 0x40, 0x52, 0x42, 0x00, 0x2e, 0x00, 0x40, 0x40, 0x42,
0x00, 0x2e, 0x03, 0x2e, 0xd0, 0x00, 0xe0, 0x6f, 0x98, 0x2e, 0x95, 0xcf, 0xb1, 0x6f, 0x23, 0x2e, 0xcf, 0x00, 0x06,
0x2d, 0x37, 0x2e, 0xce, 0x00, 0xe0, 0x6f, 0x01, 0x30, 0x98, 0x2e, 0x95, 0xcf, 0xfb, 0x6f, 0x70, 0x5f, 0xb8, 0x2e,
0xd0, 0x50, 0x80, 0x7f, 0x91, 0x7f, 0xd7, 0x7f, 0xc5, 0x7f, 0xb3, 0x7f, 0xa2, 0x7f, 0xe4, 0x7f, 0xf6, 0x7f, 0x7b,
0x7f, 0x00, 0x2e, 0x35, 0x50, 0x00, 0x2e, 0x01, 0x40, 0x9f, 0xbc, 0x9f, 0xb8, 0x40, 0x90, 0x02, 0x2f, 0x31, 0x30,
0x23, 0x2e, 0x69, 0xf5, 0x38, 0x82, 0x61, 0x7f, 0x20, 0x30, 0x41, 0x40, 0x23, 0x2e, 0xd6, 0x00, 0x03, 0x2e, 0xd6,
0x00, 0x08, 0x08, 0x00, 0xb2, 0x11, 0x2f, 0x33, 0x50, 0x1a, 0x25, 0x12, 0x40, 0x32, 0x7f, 0x73, 0x82, 0x12, 0x40,
0x42, 0x7f, 0x00, 0x2e, 0x00, 0x40, 0x50, 0x7f, 0x98, 0x2e, 0x6a, 0xd6, 0x01, 0x2e, 0x61, 0xf7, 0x01, 0x31, 0x01,
0x0a, 0x21, 0x2e, 0x61, 0xf7, 0x80, 0x30, 0x03, 0x2e, 0xd6, 0x00, 0x08, 0x08, 0x00, 0xb2, 0x40, 0x2f, 0x03, 0x2e,
0x89, 0x00, 0x17, 0xbc, 0x96, 0xbc, 0x0f, 0xb8, 0x9f, 0xb8, 0x40, 0x90, 0x21, 0x2e, 0x6f, 0x01, 0x10, 0x30, 0x01,
0x30, 0x2a, 0x2f, 0x03, 0x2e, 0x6b, 0x01, 0x44, 0xb2, 0x05, 0x2f, 0x47, 0xb2, 0x00, 0x30, 0x2d, 0x2f, 0x21, 0x2e,
0xd6, 0x00, 0x2b, 0x2d, 0x03, 0x2e, 0xfd, 0xf5, 0x9e, 0xbc, 0x9f, 0xb8, 0x40, 0x90, 0x14, 0x2f, 0x03, 0x2e, 0xfc,
0xf5, 0x99, 0xbc, 0x9f, 0xb8, 0x40, 0x90, 0x0e, 0x2f, 0x03, 0x2e, 0x49, 0xf1, 0x37, 0x54, 0x4a, 0x08, 0x40, 0x90,
0x08, 0x2f, 0x98, 0x2e, 0xe9, 0x01, 0x00, 0xb2, 0x10, 0x30, 0x03, 0x2f, 0x50, 0x30, 0x21, 0x2e, 0x6b, 0x01, 0x10,
0x2d, 0x98, 0x2e, 0x24, 0xb6, 0x00, 0x30, 0x21, 0x2e, 0xd6, 0x00, 0x0a, 0x2d, 0x05, 0x2e, 0x69, 0xf7, 0x2d, 0xbd,
0x2f, 0xb9, 0x80, 0xb2, 0x01, 0x2f, 0x21, 0x2e, 0xd7, 0x00, 0x23, 0x2e, 0xd6, 0x00, 0x60, 0x6f, 0xe1, 0x31, 0x01,
0x42, 0x00, 0x2e, 0xf6, 0x6f, 0xe4, 0x6f, 0x80, 0x6f, 0x91, 0x6f, 0xa2, 0x6f, 0xb3, 0x6f, 0xc5, 0x6f, 0xd7, 0x6f,
0x7b, 0x6f, 0x30, 0x5f, 0xc8, 0x2e, 0xa0, 0x50, 0x82, 0x7f, 0x90, 0x7f, 0xd7, 0x7f, 0xc5, 0x7f, 0xb3, 0x7f, 0xa1,
0x7f, 0xe4, 0x7f, 0xf6, 0x7f, 0x7b, 0x7f, 0x00, 0x2e, 0x35, 0x54, 0x00, 0x2e, 0x80, 0x40, 0x0f, 0xbc, 0x0f, 0xb8,
0x00, 0x90, 0x02, 0x2f, 0x30, 0x30, 0x21, 0x2e, 0x69, 0xf5, 0xb7, 0x84, 0x62, 0x7f, 0x98, 0x2e, 0xe9, 0x01, 0x00,
0xb2, 0x90, 0x2e, 0x7f, 0xb3, 0x05, 0x2e, 0xa0, 0x00, 0x03, 0x2e, 0x8c, 0x00, 0x01, 0x2e, 0x8e, 0x00, 0xa3, 0xbd,
0x9f, 0xb8, 0x0f, 0xb8, 0x08, 0x0a, 0xbf, 0xb9, 0xa4, 0xbc, 0x03, 0x0a, 0x22, 0xbe, 0x9f, 0xb8, 0x07, 0x2e, 0x96,
0x00, 0x41, 0x0a, 0x4f, 0xba, 0x05, 0x2e, 0x98, 0x00, 0xb3, 0xbd, 0x0c, 0x0b, 0x01, 0x2e, 0x90, 0x00, 0xbf, 0xb9,
0x2f, 0xbd, 0x03, 0x2e, 0x9f, 0x00, 0x2f, 0xb9, 0x0f, 0xbc, 0xe3, 0x0a, 0x0f, 0xb8, 0x9f, 0xbc, 0x9a, 0x0a, 0x9f,
0xb8, 0x90, 0x0a, 0x91, 0x0a, 0x25, 0x2e, 0x79, 0x00, 0x05, 0x2e, 0xc1, 0xf5, 0x2e, 0xbd, 0x2e, 0xb9, 0x01, 0x2e,
0x7b, 0x00, 0x31, 0x30, 0x8a, 0x04, 0x00, 0x90, 0x0b, 0x2f, 0x01, 0x2e, 0x6b, 0x01, 0x04, 0xa2, 0x07, 0x2f, 0x01,
0x2e, 0x79, 0x00, 0x00, 0x90, 0x03, 0x2f, 0x01, 0x2e, 0xd9, 0x00, 0x00, 0xb2, 0x19, 0x2f, 0x3b, 0x50, 0x09, 0x52,
0x98, 0x2e, 0x01, 0x02, 0x05, 0x2e, 0xd8, 0x00, 0x25, 0x2e, 0x87, 0x01, 0x05, 0x2e, 0xd8, 0x00, 0x80, 0x90, 0x02,
0x2f, 0x12, 0x30, 0x25, 0x2e, 0xd8, 0x00, 0x01, 0x2e, 0xd9, 0x00, 0x00, 0xb2, 0x10, 0x30, 0x05, 0x2e, 0x79, 0x00,
0x01, 0x2f, 0x21, 0x2e, 0x79, 0x00, 0x25, 0x2e, 0xd9, 0x00, 0x98, 0x2e, 0xf2, 0x01, 0x00, 0xb2, 0x22, 0x30, 0x21,
0x30, 0x03, 0x2f, 0x01, 0x2e, 0x7b, 0x00, 0x00, 0x90, 0x05, 0x2f, 0x01, 0x2e, 0x7a, 0x00, 0x00, 0x90, 0x30, 0x30,
0x01, 0x30, 0x41, 0x22, 0x01, 0x2e, 0x94, 0x01, 0x08, 0x1a, 0x0e, 0x2f, 0x23, 0x2e, 0x94, 0x01, 0x33, 0x30, 0x3d,
0x50, 0x0b, 0x09, 0x01, 0x40, 0x39, 0x56, 0x46, 0xbe, 0x4b, 0x08, 0x4c, 0x0a, 0x01, 0x42, 0x0a, 0x80, 0x25, 0x52,
0x01, 0x42, 0x00, 0x2e, 0x01, 0x2e, 0x79, 0x00, 0x00, 0xb2, 0x1f, 0x2f, 0x03, 0x2e, 0xc0, 0xf5, 0xf0, 0x30, 0x48,
0x08, 0x47, 0xaa, 0x74, 0x30, 0x07, 0x2e, 0xdc, 0x00, 0x61, 0x22, 0x4b, 0x1a, 0x05, 0x2f, 0x07, 0x2e, 0x66, 0xf5,
0xbf, 0xbd, 0xbf, 0xb9, 0xc0, 0x90, 0x0b, 0x2f, 0x3f, 0x56, 0x04, 0x30, 0xd4, 0x42, 0xd2, 0x42, 0x81, 0x04, 0x24,
0xbd, 0xfe, 0x80, 0x81, 0x84, 0xc4, 0x42, 0x23, 0x2e, 0xdc, 0x00, 0x02, 0x42, 0x02, 0x32, 0x25, 0x2e, 0x62, 0xf5,
0x05, 0x2e, 0x6d, 0x01, 0x81, 0x80, 0x03, 0x2e, 0x8a, 0x00, 0x21, 0x2e, 0x6d, 0x01, 0x0f, 0x56, 0x62, 0x6f, 0x4b,
0x08, 0x00, 0x31, 0x80, 0x42, 0x40, 0xb2, 0x0b, 0x2f, 0xf2, 0x3e, 0x01, 0x2e, 0xca, 0xf5, 0x82, 0x08, 0x25, 0x2e,
0xca, 0xf5, 0x05, 0x2e, 0x59, 0xf5, 0xe0, 0x3f, 0x90, 0x08, 0x25, 0x2e, 0x59, 0xf5, 0xf6, 0x6f, 0xe4, 0x6f, 0xa1,
0x6f, 0xb3, 0x6f, 0xc5, 0x6f, 0xd7, 0x6f, 0x7b, 0x6f, 0x82, 0x6f, 0x90, 0x6f, 0x60, 0x5f, 0xc8, 0x2e, 0xc0, 0x50,
0x80, 0x7f, 0x92, 0x7f, 0xd5, 0x7f, 0xc4, 0x7f, 0xb3, 0x7f, 0xa1, 0x7f, 0xe7, 0x7f, 0xf6, 0x7f, 0x7b, 0x7f, 0x00,
0x2e, 0x35, 0x50, 0x00, 0x2e, 0x02, 0x40, 0x2f, 0xbd, 0x2f, 0xb9, 0x80, 0x90, 0x02, 0x2f, 0x32, 0x30, 0x25, 0x2e,
0x69, 0xf5, 0x37, 0x80, 0x00, 0x2e, 0x00, 0x40, 0x60, 0x7f, 0x98, 0x2e, 0xe9, 0x01, 0x0b, 0x30, 0x5b, 0x7f, 0x40,
0x7f, 0x02, 0x32, 0x64, 0x6f, 0x25, 0x52, 0x43, 0x56, 0x0b, 0x30, 0x80, 0x2e, 0x65, 0xb4, 0x62, 0x09, 0x40, 0xb3,
0x0b, 0x2f, 0x00, 0xb2, 0x03, 0x2f, 0x0b, 0x2e, 0x79, 0x00, 0x40, 0x91, 0x03, 0x2f, 0xc2, 0x8a, 0x25, 0x2e, 0x64,
0xf5, 0x4b, 0x43, 0x25, 0x2e, 0x60, 0xf5, 0x21, 0x09, 0x00, 0xb3, 0x79, 0x2f, 0x98, 0x2e, 0xf2, 0x01, 0x00, 0xb2,
0x06, 0x2f, 0x01, 0x2e, 0x7b, 0x00, 0x00, 0xb2, 0x02, 0x2f, 0x40, 0x6f, 0x00, 0x90, 0x0a, 0x2f, 0x01, 0x2e, 0xdb,
0x00, 0x00, 0x90, 0x19, 0x2f, 0x10, 0x30, 0x21, 0x2e, 0xdb, 0x00, 0x00, 0x30, 0x98, 0x2e, 0x0d, 0xb6, 0x13, 0x2d,
0x01, 0x2e, 0xc3, 0xf5, 0x0c, 0xbc, 0x0f, 0xb8, 0x12, 0x30, 0x10, 0x04, 0x03, 0xb0, 0x26, 0x25, 0x45, 0x50, 0x07,
0x52, 0x98, 0x2e, 0x01, 0x02, 0x10, 0x30, 0x21, 0x2e, 0x99, 0x01, 0x02, 0x30, 0x50, 0x7f, 0x25, 0x2e, 0xdb, 0x00,
0x40, 0x6f, 0x00, 0xb2, 0x03, 0x2f, 0x05, 0x2e, 0x7a, 0x00, 0x80, 0x90, 0x0e, 0x2f, 0x05, 0x2e, 0xda, 0x00, 0x80,
0x90, 0x36, 0x2f, 0x11, 0x30, 0x02, 0x30, 0x23, 0x2e, 0xda, 0x00, 0x23, 0x2e, 0x74, 0x01, 0x25, 0x2e, 0x7d, 0x00,
0x25, 0x2e, 0x9e, 0x01, 0x2c, 0x2d, 0x05, 0x2e, 0x9e, 0x01, 0x81, 0x82, 0x23, 0x2e, 0x9e, 0x01, 0x12, 0x30, 0x4a,
0x08, 0x40, 0xb2, 0x05, 0x2f, 0x03, 0x2e, 0x58, 0xf5, 0x98, 0xbc, 0x9e, 0xb8, 0x43, 0x90, 0x1a, 0x2f, 0x01, 0x2e,
0xc1, 0xf5, 0x0e, 0xbd, 0x30, 0x30, 0x2e, 0xb9, 0x82, 0x04, 0x01, 0x52, 0x47, 0x50, 0x62, 0x7f, 0x98, 0x2e, 0x01,
0x02, 0x01, 0x2e, 0xdd, 0x00, 0x01, 0x90, 0x49, 0x50, 0x03, 0x52, 0x02, 0x2f, 0x62, 0x6f, 0x98, 0x2e, 0x01, 0x02,
0x12, 0x30, 0x25, 0x2e, 0x9d, 0x01, 0x00, 0x30, 0x21, 0x2e, 0xda, 0x00, 0x40, 0x6f, 0x52, 0x7f, 0x00, 0x2e, 0x52,
0x6f, 0x80, 0x90, 0x05, 0x2f, 0x02, 0x30, 0x25, 0x2e, 0x94, 0x01, 0x25, 0x54, 0x25, 0x2e, 0x64, 0xf5, 0x25, 0x52,
0x23, 0x2e, 0x60, 0xf5, 0x02, 0x32, 0x43, 0x56, 0x0b, 0x30, 0x00, 0x90, 0x0b, 0x2f, 0x37, 0x2e, 0xd8, 0x00, 0x41,
0x50, 0x21, 0x2e, 0x5a, 0xf2, 0x98, 0x2e, 0xdd, 0x03, 0x40, 0x6f, 0x02, 0x32, 0x25, 0x52, 0x43, 0x56, 0x0b, 0x30,
0x09, 0x2e, 0x60, 0xf5, 0x62, 0x09, 0x40, 0x91, 0x90, 0x2e, 0xc9, 0xb3, 0x61, 0x09, 0x40, 0x91, 0x90, 0x2e, 0xc9,
0xb3, 0x80, 0x6f, 0x92, 0x6f, 0xa1, 0x6f, 0xb3, 0x6f, 0xc4, 0x6f, 0xd5, 0x6f, 0x7b, 0x6f, 0xf6, 0x6f, 0xe7, 0x6f,
0x40, 0x5f, 0xc8, 0x2e, 0x4b, 0x52, 0x00, 0x51, 0x52, 0x40, 0x47, 0x40, 0xf8, 0xbc, 0x9c, 0xb9, 0x01, 0x2e, 0x9f,
0x00, 0xf3, 0x7f, 0x8f, 0xbd, 0x3f, 0xba, 0x1a, 0x25, 0x78, 0xb8, 0x59, 0x56, 0xd3, 0x08, 0x75, 0x8c, 0x73, 0x8a,
0xeb, 0x7f, 0xfc, 0xbf, 0xd4, 0x7f, 0x0b, 0x30, 0xfc, 0xbb, 0x1c, 0x0b, 0x4b, 0x7f, 0x8b, 0x43, 0x4b, 0x43, 0x21,
0x2e, 0xe4, 0x00, 0x00, 0xb3, 0xa7, 0x7f, 0xb5, 0x7f, 0xc6, 0x7f, 0x93, 0x7f, 0x90, 0x2e, 0x35, 0xb5, 0x01, 0x2e,
0xfe, 0x00, 0x00, 0xb2, 0x0b, 0x2f, 0x4f, 0x52, 0x01, 0x2e, 0xf9, 0x00, 0x82, 0x7f, 0x98, 0x2e, 0xbb, 0xcc, 0x0b,
0x30, 0x37, 0x2e, 0xfe, 0x00, 0x82, 0x6f, 0x93, 0x6f, 0x1a, 0x25, 0xc0, 0xb2, 0x8b, 0x7f, 0x14, 0x2f, 0x26, 0xbc,
0x25, 0xbd, 0x06, 0xb8, 0x2f, 0xb9, 0x80, 0xb2, 0x14, 0xb0, 0x0c, 0x2f, 0x51, 0x50, 0x53, 0x54, 0x0b, 0x30, 0x0b,
0x2e, 0xa0, 0x00, 0x57, 0x58, 0x1b, 0x42, 0x9b, 0x42, 0x6c, 0x09, 0x2b, 0x2e, 0xa0, 0x00, 0x0b, 0x42, 0x8b, 0x42,
0x86, 0x7f, 0x70, 0x84, 0x5b, 0x50, 0xd8, 0x08, 0x55, 0x52, 0x09, 0x50, 0x72, 0x7f, 0x63, 0x7f, 0x98, 0x2e, 0xc2,
0xc0, 0xd1, 0x6f, 0x62, 0x6f, 0xd1, 0x0a, 0x01, 0x2e, 0xf9, 0x00, 0xc5, 0x6f, 0xb4, 0x6f, 0x72, 0x6f, 0x4f, 0x52,
0x4d, 0x5c, 0x98, 0x2e, 0x06, 0xcd, 0x53, 0x6f, 0x90, 0x6f, 0x51, 0x52, 0xc0, 0xb2, 0x04, 0xbd, 0x54, 0x40, 0xaf,
0xb9, 0x45, 0x40, 0xd1, 0x7f, 0x02, 0x30, 0x06, 0x2f, 0xc0, 0xb2, 0x02, 0x30, 0x03, 0x2f, 0x53, 0x5c, 0x12, 0x30,
0x94, 0x43, 0x85, 0x43, 0x03, 0xbf, 0x6f, 0xbb, 0x80, 0xb3, 0x20, 0x2f, 0x36, 0x6f, 0x26, 0x01, 0x46, 0x6f, 0x6e,
0x03, 0x45, 0x42, 0xc0, 0x90, 0x29, 0x2e, 0xfa, 0x00, 0x53, 0x52, 0x14, 0x2f, 0x53, 0x5c, 0x00, 0x2e, 0x93, 0x41,
0x86, 0x41, 0xe3, 0x04, 0xae, 0x07, 0x80, 0xab, 0x04, 0x2f, 0x80, 0x91, 0x0a, 0x2f, 0x86, 0x6f, 0x73, 0x0f, 0x07,
0x2f, 0x83, 0x6f, 0xc0, 0xb2, 0x04, 0x2f, 0x54, 0x42, 0x45, 0x42, 0x12, 0x30, 0x04, 0x2c, 0x11, 0x30, 0x02, 0x2c,
0x11, 0x30, 0x11, 0x30, 0x02, 0xbc, 0x0f, 0xb8, 0xc2, 0x7f, 0x00, 0x90, 0x06, 0x2f, 0x31, 0x30, 0x23, 0x2e, 0x78,
0x01, 0x23, 0x2e, 0xdf, 0x00, 0x0b, 0x2c, 0x01, 0x30, 0x01, 0x2e, 0xdf, 0x00, 0x05, 0x2e, 0x78, 0x01, 0x10, 0x1a,
0x02, 0x2f, 0x21, 0x2e, 0x78, 0x01, 0x01, 0x2d, 0x01, 0x30, 0xf0, 0x6f, 0x98, 0x2e, 0x95, 0xcf, 0xc1, 0x6f, 0xa0,
0x6f, 0x98, 0x2e, 0x95, 0xcf, 0xd2, 0x6f, 0x21, 0x52, 0x01, 0x2e, 0xfa, 0x00, 0x82, 0x40, 0x50, 0x42, 0x11, 0x2c,
0x42, 0x42, 0x10, 0x30, 0x31, 0x30, 0x21, 0x2e, 0xfe, 0x00, 0x23, 0x2e, 0x78, 0x01, 0x23, 0x2e, 0xdf, 0x00, 0xf0,
0x6f, 0x01, 0x30, 0x98, 0x2e, 0x95, 0xcf, 0xa0, 0x6f, 0x01, 0x30, 0x98, 0x2e, 0x95, 0xcf, 0x00, 0x2e, 0xeb, 0x6f,
0x00, 0x5f, 0xb8, 0x2e, 0x07, 0x2e, 0x9f, 0x00, 0x3b, 0xbc, 0x60, 0x50, 0xbf, 0xbd, 0x0c, 0xb8, 0xf0, 0x7f, 0xc0,
0xb2, 0xeb, 0x7f, 0x2d, 0x2f, 0x07, 0x2e, 0xff, 0x00, 0xc3, 0x40, 0x01, 0x2e, 0x69, 0x01, 0x03, 0x1a, 0x11, 0x2f,
0x5f, 0x52, 0x27, 0x2e, 0x69, 0x01, 0x50, 0x40, 0xa0, 0x7f, 0x78, 0x80, 0x43, 0x40, 0xd0, 0x7f, 0xb3, 0x7f, 0x98,
0x2e, 0x64, 0xcf, 0xd0, 0x6f, 0x07, 0x80, 0xa3, 0x6f, 0x13, 0x42, 0x00, 0x2e, 0xb3, 0x6f, 0x03, 0x42, 0x03, 0x30,
0x01, 0x2e, 0xdf, 0x00, 0x01, 0xb2, 0x01, 0x2f, 0x02, 0x90, 0x00, 0x2f, 0x13, 0x30, 0x1a, 0x25, 0x7c, 0x88, 0x01,
0x2e, 0xff, 0x00, 0x5d, 0x52, 0x09, 0x54, 0x98, 0x2e, 0xc4, 0xce, 0xc1, 0x6f, 0xf0, 0x6f, 0x98, 0x2e, 0x95, 0xcf,
0x04, 0x2d, 0x01, 0x30, 0xf0, 0x6f, 0x98, 0x2e, 0x95, 0xcf, 0xeb, 0x6f, 0xa0, 0x5f, 0xb8, 0x2e, 0x60, 0x51, 0x0a,
0x25, 0x36, 0x88, 0xf4, 0x7f, 0xeb, 0x7f, 0x00, 0x32, 0x6b, 0x52, 0x32, 0x30, 0x13, 0x30, 0x98, 0x2e, 0x15, 0xcb,
0x0a, 0x25, 0x33, 0x84, 0xd2, 0x7f, 0x43, 0x30, 0x09, 0x50, 0x67, 0x52, 0x98, 0x2e, 0x95, 0xc1, 0xd2, 0x6f, 0x61,
0x52, 0x98, 0x2e, 0xd7, 0xc7, 0x2a, 0x25, 0xb0, 0x86, 0xc0, 0x7f, 0xd3, 0x7f, 0xaf, 0x84, 0x63, 0x50, 0xf1, 0x6f,
0x98, 0x2e, 0x4d, 0xc8, 0x2a, 0x25, 0xae, 0x8a, 0xaa, 0x88, 0xf2, 0x6e, 0x65, 0x50, 0xc1, 0x6f, 0xd3, 0x6f, 0xf4,
0x7f, 0x98, 0x2e, 0xb6, 0xc8, 0xe0, 0x6e, 0x00, 0xb2, 0x32, 0x2f, 0x6d, 0x54, 0x83, 0x86, 0xf1, 0x6f, 0xc3, 0x7f,
0x04, 0x30, 0x30, 0x30, 0xf4, 0x7f, 0xd0, 0x7f, 0xb2, 0x7f, 0xe3, 0x30, 0xc5, 0x6f, 0x56, 0x40, 0x45, 0x41, 0x28,
0x08, 0x03, 0x14, 0x0e, 0xb4, 0x08, 0xbc, 0x82, 0x40, 0x10, 0x0a, 0x69, 0x54, 0x26, 0x05, 0x91, 0x7f, 0x44, 0x28,
0xa3, 0x7f, 0x98, 0x2e, 0xd9, 0xc0, 0x08, 0xb9, 0x33, 0x30, 0x53, 0x09, 0xc1, 0x6f, 0xd3, 0x6f, 0xf4, 0x6f, 0x83,
0x17, 0x47, 0x40, 0x6c, 0x15, 0xb2, 0x6f, 0xbe, 0x09, 0x75, 0x0b, 0x90, 0x42, 0x45, 0x42, 0x51, 0x0e, 0x32, 0xbc,
0x02, 0x89, 0xa1, 0x6f, 0x7e, 0x86, 0xf4, 0x7f, 0xd0, 0x7f, 0xb2, 0x7f, 0x04, 0x30, 0x91, 0x6f, 0xd6, 0x2f, 0xeb,
0x6f, 0xa0, 0x5e, 0xb8, 0x2e, 0x01, 0x2e, 0x77, 0xf7, 0x09, 0xbc, 0x0f, 0xb8, 0x00, 0xb2, 0x10, 0x50, 0xfb, 0x7f,
0x10, 0x30, 0x0b, 0x2f, 0x03, 0x2e, 0x8a, 0x00, 0x96, 0xbc, 0x9f, 0xb8, 0x40, 0xb2, 0x05, 0x2f, 0x03, 0x2e, 0x68,
0xf7, 0x9e, 0xbc, 0x9f, 0xb8, 0x40, 0xb2, 0x07, 0x2f, 0x03, 0x2e, 0x6a, 0x01, 0x41, 0x90, 0x01, 0x2f, 0x98, 0x2e,
0x0d, 0xb6, 0x03, 0x2c, 0x00, 0x30, 0x21, 0x2e, 0x6a, 0x01, 0xfb, 0x6f, 0xf0, 0x5f, 0xb8, 0x2e, 0x20, 0x50, 0xe0,
0x7f, 0xfb, 0x7f, 0x00, 0x2e, 0x61, 0x50, 0x98, 0x2e, 0x3b, 0xc8, 0x63, 0x50, 0x98, 0x2e, 0xa7, 0xc8, 0x05, 0x50,
0x98, 0x2e, 0x55, 0xcc, 0xe1, 0x6f, 0x65, 0x50, 0x98, 0x2e, 0xe0, 0xc9, 0xfb, 0x6f, 0x00, 0x30, 0xe0, 0x5f, 0x21,
0x2e, 0x6a, 0x01, 0xb8, 0x2e, 0x03, 0xbc, 0x21, 0x2e, 0x6c, 0x01, 0x03, 0x2e, 0x6c, 0x01, 0x40, 0xb2, 0x10, 0x30,
0x21, 0x2e, 0x7c, 0x00, 0x01, 0x30, 0x05, 0x2f, 0x05, 0x2e, 0x6f, 0x01, 0x80, 0x90, 0x01, 0x2f, 0x23, 0x2e, 0x6f,
0xf5, 0xc0, 0x2e, 0x21, 0x2e, 0x70, 0x01, 0x30, 0x25, 0x00, 0x30, 0x21, 0x2e, 0x5a, 0xf5, 0x10, 0x50, 0x21, 0x2e,
0xde, 0x00, 0x21, 0x2e, 0xd6, 0x00, 0xfb, 0x7f, 0x98, 0x2e, 0xf5, 0x03, 0x40, 0x30, 0x21, 0x2e, 0x6b, 0x01, 0xfb,
0x6f, 0xf0, 0x5f, 0x03, 0x25, 0x80, 0x2e, 0x24, 0xb6, 0x01, 0x2e, 0xa8, 0x00, 0x31, 0x25, 0x08, 0xbd, 0x71, 0x30,
0x20, 0x50, 0x2c, 0xb9, 0x01, 0x09, 0xf2, 0x7f, 0x00, 0x91, 0xeb, 0x7f, 0x0a, 0x2f, 0x01, 0x30, 0xf0, 0x6f, 0x98,
0x2e, 0x95, 0xcf, 0x13, 0x30, 0x27, 0x2e, 0x74, 0x01, 0xeb, 0x6f, 0xc0, 0x2e, 0x00, 0x30, 0xe0, 0x5f, 0x01, 0x2e,
0x74, 0x01, 0x00, 0xb2, 0x05, 0x2f, 0x06, 0x30, 0xc3, 0x50, 0x98, 0x2e, 0x84, 0xb6, 0x2d, 0x2e, 0x74, 0x01, 0x05,
0x2e, 0x73, 0x01, 0x8b, 0x80, 0xc3, 0x52, 0x04, 0x42, 0x98, 0x2e, 0xbf, 0xb6, 0x10, 0x25, 0xf0, 0x6f, 0xf1, 0x7f,
0x98, 0x2e, 0x95, 0xcf, 0xf0, 0x6f, 0x00, 0x90, 0x02, 0x2f, 0x01, 0x2e, 0x75, 0x01, 0x02, 0x2d, 0x21, 0x2e, 0x75,
0x01, 0xeb, 0x6f, 0xe0, 0x5f, 0xb8, 0x2e, 0x0a, 0x82, 0x02, 0x30, 0x12, 0x42, 0x41, 0x0e, 0xfc, 0x2f, 0x37, 0x80,
0xc5, 0x52, 0x11, 0x42, 0x00, 0x2e, 0xc7, 0x52, 0x01, 0x42, 0xb8, 0x2e, 0x07, 0x88, 0x46, 0x8e, 0x06, 0x41, 0x3c,
0x8b, 0x32, 0x1a, 0x42, 0x41, 0xc7, 0x41, 0x16, 0x2f, 0x80, 0x91, 0x23, 0x2f, 0x57, 0x0f, 0x16, 0x30, 0x0c, 0x2f,
0x06, 0x80, 0x00, 0x2e, 0x00, 0x40, 0x00, 0xb2, 0x04, 0x2f, 0x45, 0x82, 0x00, 0x2e, 0x41, 0x40, 0xd1, 0x0f, 0x02,
0x2f, 0x06, 0x30, 0x06, 0x43, 0x46, 0x43, 0x80, 0xb3, 0x11, 0x2f, 0x03, 0x43, 0x47, 0x43, 0xb8, 0x2e, 0xd7, 0x0e,
0x0c, 0x2f, 0x43, 0x82, 0x17, 0x04, 0x41, 0x40, 0x41, 0x0f, 0x07, 0x2f, 0x03, 0x43, 0x42, 0x83, 0x47, 0x43, 0x00,
0x2e, 0x43, 0x40, 0xc1, 0x86, 0x43, 0x42, 0xb8, 0x2e, 0xb8, 0x2e, 0x88, 0x88, 0xc0, 0x50, 0x39, 0x8d, 0x88, 0x81,
0xe2, 0x7f, 0x02, 0x30, 0x05, 0x40, 0xf2, 0x7f, 0x41, 0xab, 0x22, 0x30, 0x95, 0x22, 0x86, 0x41, 0x27, 0x5e, 0x9a,
0x00, 0x04, 0x41, 0x37, 0x18, 0x66, 0x01, 0xc9, 0x56, 0xeb, 0x00, 0xc1, 0x7f, 0xb3, 0x7f, 0xd5, 0x7f, 0x48, 0x82,
0x39, 0x80, 0x82, 0x40, 0xa0, 0x7f, 0x91, 0x7f, 0x8b, 0x7f, 0x06, 0x30, 0x6f, 0x5a, 0xcb, 0x58, 0x6f, 0x56, 0x98,
0x2e, 0x67, 0xcc, 0x91, 0x6f, 0x7b, 0x82, 0xc6, 0x6f, 0x42, 0x40, 0x81, 0x84, 0x42, 0x42, 0x43, 0x82, 0x83, 0x8b,
0x42, 0x40, 0x86, 0x89, 0x7b, 0x82, 0x84, 0x87, 0x71, 0x7f, 0x80, 0xb2, 0x95, 0x7f, 0x64, 0x7f, 0x50, 0x7f, 0x02,
0x2f, 0xc5, 0x40, 0x41, 0x8b, 0xc5, 0x42, 0x87, 0x89, 0x67, 0x40, 0x07, 0x0f, 0x85, 0x8b, 0x41, 0x7f, 0x82, 0x8d,
0x47, 0x40, 0x3c, 0x2f, 0x81, 0x41, 0x01, 0x0e, 0xe1, 0x6f, 0x2d, 0x2f, 0x46, 0x8c, 0x90, 0x6f, 0x86, 0x41, 0x07,
0x40, 0xfe, 0x0e, 0x02, 0x2f, 0x04, 0x41, 0x00, 0xb3, 0x21, 0x2f, 0x44, 0x82, 0x04, 0x30, 0x41, 0x40, 0x71, 0x00,
0xf9, 0x0e, 0x36, 0x2f, 0x46, 0x41, 0x80, 0xa7, 0x01, 0x30, 0x04, 0x30, 0x0d, 0x2f, 0xe4, 0x6f, 0x00, 0x2e, 0x04,
0x41, 0x74, 0x0f, 0x04, 0x30, 0x07, 0x2f, 0x80, 0x90, 0x00, 0x2f, 0xc1, 0x42, 0x03, 0x86, 0x81, 0x84, 0xc2, 0x42,
0x01, 0x42, 0x14, 0x30, 0x42, 0x85, 0x41, 0x43, 0xa1, 0x42, 0x00, 0x2e, 0x82, 0x40, 0x80, 0x90, 0x1c, 0x2f, 0x01,
0x42, 0x1b, 0x2d, 0x06, 0x42, 0x19, 0x2c, 0x04, 0x30, 0xb2, 0x6f, 0xba, 0x04, 0x02, 0x1e, 0x80, 0x43, 0x12, 0x30,
0xc0, 0x6f, 0x23, 0x30, 0x98, 0x2e, 0x90, 0xb6, 0x0e, 0x2c, 0x04, 0x30, 0xb2, 0x6f, 0xc0, 0x6f, 0xba, 0x00, 0x51,
0x6f, 0x01, 0x86, 0x4a, 0x1c, 0xc1, 0x42, 0x22, 0x30, 0xe1, 0x6f, 0x13, 0x30, 0x98, 0x2e, 0x90, 0xb6, 0x04, 0x30,
0x52, 0x6f, 0xcd, 0x52, 0x40, 0x6f, 0xc4, 0x7f, 0x98, 0x2e, 0xa0, 0xcc, 0x41, 0x6f, 0x70, 0x6f, 0x42, 0x40, 0xcf,
0x52, 0x98, 0x2e, 0xa0, 0xcc, 0x41, 0x6f, 0x70, 0x6f, 0x42, 0x40, 0x01, 0x40, 0xd3, 0x6f, 0xd3, 0x00, 0xcb, 0x1e,
0xcf, 0x52, 0x13, 0x42, 0xb0, 0x7f, 0x98, 0x2e, 0xa0, 0xcc, 0xb0, 0x6f, 0x3e, 0x84, 0xd1, 0x6f, 0x82, 0x40, 0x03,
0x40, 0x51, 0x04, 0x59, 0x1c, 0x01, 0x42, 0x02, 0x82, 0xa0, 0x6f, 0x42, 0x40, 0x03, 0x40, 0xd3, 0x0f, 0x00, 0x30,
0x14, 0x30, 0x60, 0x22, 0xc5, 0x6f, 0x40, 0x91, 0x01, 0x2f, 0x53, 0x0e, 0x26, 0x2f, 0xe5, 0x6f, 0x47, 0x85, 0x00,
0x2e, 0x83, 0x40, 0x59, 0x0f, 0x20, 0x2f, 0x62, 0x6f, 0x4a, 0x8f, 0x85, 0x40, 0xc7, 0x41, 0x7f, 0x8d, 0x6f, 0x0f,
0xa6, 0x15, 0x17, 0x30, 0x04, 0x30, 0x0f, 0x2f, 0xe0, 0x6f, 0x0b, 0x80, 0x00, 0x2e, 0x07, 0x40, 0x3e, 0x08, 0x00,
0xb2, 0x00, 0x30, 0x06, 0x2f, 0x59, 0x1a, 0x04, 0x2f, 0xfd, 0x12, 0xc0, 0x90, 0x13, 0x30, 0x4b, 0x22, 0x06, 0x25,
0x71, 0x25, 0xc0, 0xb3, 0x04, 0x2f, 0xa4, 0x42, 0xa4, 0x42, 0x83, 0x82, 0x84, 0x42, 0x44, 0x42, 0x00, 0x2e, 0x8b,
0x6f, 0x40, 0x5f, 0xb8, 0x2e, 0x40, 0x50, 0x0a, 0x25, 0x3c, 0x80, 0xfb, 0x7f, 0x01, 0x42, 0xd2, 0x7f, 0xe3, 0x7f,
0x32, 0x30, 0x10, 0x25, 0x98, 0x2e, 0x7a, 0xc1, 0xfb, 0x6f, 0xc0, 0x5f, 0xb8, 0x2e, 0x70, 0x50, 0x0a, 0x25, 0x39,
0x80, 0xf3, 0x7f, 0x03, 0x42, 0xa1, 0x7f, 0xc2, 0x7f, 0xd1, 0x7f, 0x03, 0x30, 0x03, 0x43, 0xe4, 0x7f, 0xbb, 0x7f,
0x22, 0x30, 0x10, 0x25, 0x98, 0x2e, 0x7a, 0xc1, 0xd2, 0x6f, 0x02, 0x17, 0x04, 0x08, 0xc1, 0x6f, 0x0c, 0x09, 0x04,
0x1a, 0x10, 0x30, 0x04, 0x30, 0x20, 0x22, 0x01, 0xb2, 0x14, 0x2f, 0xd1, 0x58, 0x14, 0x09, 0xf3, 0x30, 0x93, 0x08,
0x24, 0xbd, 0x44, 0xba, 0x94, 0x0a, 0x02, 0x17, 0xf3, 0x6f, 0x4c, 0x08, 0x9a, 0x08, 0x8a, 0x0a, 0x9d, 0x52, 0x51,
0x08, 0x41, 0x58, 0x94, 0x08, 0x28, 0xbd, 0x98, 0xb8, 0xe4, 0x6f, 0x51, 0x0a, 0x01, 0x43, 0x00, 0x2e, 0xbb, 0x6f,
0x90, 0x5f, 0xb8, 0x2e, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00,
0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x01, 0x2e, 0x5d, 0xf7, 0x08, 0xbc, 0x80, 0xac, 0x0e, 0xbb, 0x02, 0x2f,
0x00, 0x30, 0x41, 0x04, 0x82, 0x06, 0xc0, 0xa4, 0x00, 0x30, 0x11, 0x2f, 0x40, 0xa9, 0x03, 0x2f, 0x40, 0x91, 0x0d,
0x2f, 0x00, 0xa7, 0x0b, 0x2f, 0x80, 0xb3, 0x6f, 0x58, 0x02, 0x2f, 0x90, 0xa1, 0x26, 0x13, 0x20, 0x23, 0x80, 0x90,
0x10, 0x30, 0x01, 0x2f, 0xcc, 0x0e, 0x00, 0x2f, 0x00, 0x30, 0xb8, 0x2e, 0x77, 0x56, 0x71, 0x54, 0xd0, 0x40, 0xc4,
0x40, 0x0b, 0x2e, 0xfd, 0xf3, 0x77, 0x52, 0x90, 0x42, 0x94, 0x42, 0x95, 0x42, 0x05, 0x30, 0x79, 0x50, 0x0f, 0x88,
0x06, 0x40, 0x04, 0x41, 0x96, 0x42, 0xc5, 0x42, 0x48, 0xbe, 0x73, 0x30, 0x0d, 0x2e, 0x6f, 0x01, 0x4f, 0xba, 0x84,
0x42, 0x03, 0x42, 0x81, 0xb3, 0x02, 0x2f, 0x2b, 0x2e, 0x6f, 0xf5, 0x06, 0x2d, 0x05, 0x2e, 0x77, 0xf7, 0x75, 0x56,
0x93, 0x08, 0x25, 0x2e, 0x77, 0xf7, 0x73, 0x54, 0x25, 0x2e, 0xc2, 0xf5, 0x07, 0x2e, 0xfd, 0xf3, 0x42, 0x30, 0xb4,
0x33, 0xda, 0x0a, 0x4c, 0x00, 0x27, 0x2e, 0xfd, 0xf3, 0x43, 0x40, 0xd4, 0x3f, 0xdc, 0x08, 0x43, 0x42, 0x00, 0x2e,
0x00, 0x2e, 0x43, 0x40, 0x24, 0x30, 0xdc, 0x0a, 0x43, 0x42, 0x04, 0x80, 0x03, 0x2e, 0xfd, 0xf3, 0x4a, 0x0a, 0x23,
0x2e, 0xfd, 0xf3, 0x61, 0x34, 0xc0, 0x2e, 0x01, 0x42, 0x00, 0x2e, 0xd0, 0x51, 0xfb, 0x7f, 0x98, 0x2e, 0xcf, 0x0d,
0x5a, 0x25, 0x98, 0x2e, 0xf6, 0x0d, 0x6b, 0x87, 0x81, 0x54, 0xe1, 0x7f, 0xa3, 0x7f, 0xb3, 0x7f, 0xb2, 0x88, 0x7b,
0x52, 0xc2, 0x7f, 0x65, 0x8b, 0x7d, 0x56, 0x84, 0x7f, 0x61, 0x7f, 0x75, 0x7f, 0xd0, 0x7f, 0x95, 0x7f, 0x53, 0x7f,
0x14, 0x30, 0x7f, 0x54, 0x81, 0x6f, 0x42, 0x7f, 0x00, 0x2e, 0x53, 0x40, 0x45, 0x8c, 0x42, 0x40, 0x90, 0x41, 0xbb,
0x83, 0x86, 0x41, 0xd8, 0x04, 0x16, 0x06, 0x00, 0xac, 0x81, 0x7f, 0x02, 0x2f, 0x02, 0x30, 0xd3, 0x04, 0x10, 0x06,
0xc1, 0x84, 0x01, 0x30, 0xc1, 0x02, 0x0b, 0x16, 0x04, 0x09, 0x14, 0x01, 0x99, 0x02, 0xc1, 0xb9, 0xaf, 0xbc, 0x59,
0x0a, 0x64, 0x6f, 0x51, 0x43, 0xa1, 0xb4, 0x12, 0x41, 0x13, 0x41, 0x41, 0x43, 0x35, 0x7f, 0x64, 0x7f, 0x26, 0x31,
0xe5, 0x6f, 0xd4, 0x6f, 0x98, 0x2e, 0x37, 0xca, 0x32, 0x6f, 0x75, 0x6f, 0x83, 0x40, 0x42, 0x41, 0x23, 0x7f, 0x12,
0x7f, 0xf6, 0x30, 0x40, 0x25, 0x51, 0x25, 0x98, 0x2e, 0x37, 0xca, 0x14, 0x6f, 0x20, 0x05, 0x70, 0x6f, 0x25, 0x6f,
0x69, 0x07, 0xa2, 0x6f, 0x31, 0x6f, 0x0b, 0x30, 0x04, 0x42, 0x9b, 0x42, 0x8b, 0x42, 0x55, 0x42, 0x32, 0x7f, 0x40,
0xa9, 0xc3, 0x6f, 0x71, 0x7f, 0x02, 0x30, 0xd0, 0x40, 0xc3, 0x7f, 0x03, 0x2f, 0x40, 0x91, 0x15, 0x2f, 0x00, 0xa7,
0x13, 0x2f, 0x00, 0xa4, 0x11, 0x2f, 0x84, 0xbd, 0x98, 0x2e, 0x79, 0xca, 0x55, 0x6f, 0x89, 0x54, 0x54, 0x41, 0x82,
0x00, 0xf3, 0x3f, 0x45, 0x41, 0xcb, 0x02, 0xf6, 0x30, 0x98, 0x2e, 0x37, 0xca, 0x33, 0x6f, 0xa4, 0x6f, 0xc1, 0x42,
0x03, 0x2c, 0x00, 0x43, 0xa4, 0x6f, 0x33, 0x6f, 0x00, 0x2e, 0x42, 0x6f, 0x55, 0x6f, 0x91, 0x40, 0x42, 0x8b, 0x00,
0x41, 0x41, 0x00, 0x01, 0x43, 0x55, 0x7f, 0x14, 0x30, 0xc1, 0x40, 0x95, 0x40, 0x4d, 0x02, 0xc5, 0x6f, 0x87, 0x50,
0x68, 0x0e, 0x75, 0x6f, 0xd1, 0x42, 0xa3, 0x7f, 0x8a, 0x2f, 0x09, 0x2e, 0x6f, 0x01, 0x01, 0xb3, 0x22, 0x2f, 0x81,
0x58, 0x90, 0x6f, 0x17, 0x30, 0x13, 0x41, 0xb6, 0x6f, 0xe4, 0x7f, 0x00, 0x2e, 0x91, 0x41, 0x14, 0x40, 0x92, 0x41,
0x15, 0x40, 0x17, 0x2e, 0x6f, 0xf5, 0xb6, 0x7f, 0xd0, 0x7f, 0xcb, 0x7f, 0x98, 0x2e, 0x00, 0x0c, 0x07, 0x15, 0xc2,
0x6f, 0x14, 0x0b, 0x29, 0x2e, 0x6f, 0xf5, 0xc3, 0xa3, 0xc1, 0x8f, 0xe4, 0x6f, 0xd0, 0x6f, 0xe6, 0x2f, 0x14, 0x30,
0x05, 0x2e, 0x6f, 0xf5, 0x14, 0x0b, 0x29, 0x2e, 0x6f, 0xf5, 0x44, 0x2d, 0x83, 0x54, 0x01, 0x32, 0x89, 0x58, 0x05,
0x30, 0x41, 0x50, 0x83, 0x40, 0xd8, 0x08, 0x91, 0x01, 0xb8, 0xbd, 0x38, 0xb5, 0xe6, 0x7f, 0x0a, 0x16, 0xb1, 0x6f,
0x2a, 0xbb, 0xa6, 0xbd, 0x1c, 0x01, 0x06, 0xbc, 0x52, 0x40, 0x06, 0x0a, 0x53, 0x40, 0x45, 0x03, 0xb1, 0x7f, 0xf6,
0x30, 0x98, 0x2e, 0x37, 0xca, 0x1a, 0xbd, 0x16, 0xb6, 0x86, 0xba, 0x00, 0xa9, 0xaa, 0x0a, 0x67, 0x52, 0x0f, 0x2f,
0x00, 0x91, 0x67, 0x52, 0x03, 0x2f, 0x67, 0x5a, 0x55, 0x0f, 0x67, 0x52, 0x08, 0x2f, 0x3f, 0xa1, 0x04, 0x2f, 0x3f,
0x91, 0x03, 0x2f, 0x89, 0x58, 0xd4, 0x0f, 0x00, 0x2f, 0x89, 0x54, 0x12, 0x25, 0xf2, 0x33, 0x98, 0x2e, 0xd9, 0xc0,
0xe4, 0x6f, 0xf5, 0x37, 0x45, 0x09, 0x21, 0x85, 0x05, 0x43, 0x05, 0x30, 0x85, 0x52, 0x51, 0x0e, 0x01, 0x32, 0x89,
0x58, 0xc5, 0x2f, 0x25, 0x54, 0x09, 0x2e, 0x77, 0xf7, 0x22, 0x0b, 0x29, 0x2e, 0x77, 0xf7, 0xfb, 0x6f, 0x30, 0x5e,
0xb8, 0x2e, 0x10, 0x50, 0x01, 0x2e, 0x6b, 0x01, 0x00, 0xb2, 0xfb, 0x7f, 0x5d, 0x2f, 0x01, 0xb2, 0x54, 0x2f, 0x02,
0xb2, 0x4e, 0x2f, 0x03, 0x90, 0x63, 0x2f, 0x8f, 0x50, 0x39, 0x82, 0x02, 0x40, 0x81, 0x88, 0x91, 0x54, 0x41, 0x40,
0x97, 0x56, 0x04, 0x42, 0x00, 0x2e, 0x94, 0x40, 0x95, 0x40, 0xd8, 0xbe, 0x2c, 0x0b, 0x45, 0x40, 0x6c, 0x01, 0x55,
0x42, 0x0c, 0x17, 0x45, 0x40, 0x2c, 0x03, 0x54, 0x42, 0x53, 0x0e, 0xf2, 0x2f, 0x99, 0x56, 0x3e, 0x82, 0xe2, 0x40,
0xc3, 0x40, 0x28, 0xbd, 0x93, 0x0a, 0x43, 0x40, 0xda, 0x00, 0x53, 0x42, 0x8a, 0x16, 0x43, 0x40, 0x9a, 0x02, 0x52,
0x42, 0x00, 0x2e, 0x41, 0x40, 0x25, 0x54, 0x4a, 0x0e, 0x3b, 0x2f, 0x3a, 0x82, 0x00, 0x30, 0x41, 0x40, 0x21, 0x2e,
0x77, 0x0f, 0x40, 0xb2, 0x0a, 0x2f, 0x98, 0x2e, 0x61, 0x0c, 0x98, 0x2e, 0x2b, 0x0e, 0x98, 0x2e, 0x41, 0x0e, 0xfb,
0x6f, 0xf0, 0x5f, 0x00, 0x30, 0x80, 0x2e, 0x38, 0xb6, 0x95, 0x54, 0x8b, 0x56, 0x83, 0x42, 0x8f, 0x86, 0x74, 0x30,
0x93, 0x54, 0xc4, 0x42, 0x11, 0x30, 0x23, 0x2e, 0x6b, 0x01, 0xa1, 0x42, 0x23, 0x30, 0x27, 0x2e, 0x6e, 0x01, 0x21,
0x2e, 0x6d, 0x01, 0xba, 0x82, 0x18, 0x2c, 0x81, 0x42, 0x30, 0x30, 0x21, 0x2e, 0x6b, 0x01, 0x13, 0x2d, 0x21, 0x30,
0x00, 0x30, 0x23, 0x2e, 0x6b, 0x01, 0x21, 0x2e, 0x7b, 0xf7, 0x0c, 0x2d, 0x77, 0x30, 0x98, 0x2e, 0x1f, 0x0c, 0x8d,
0x50, 0x0c, 0x82, 0x12, 0x30, 0x40, 0x42, 0x25, 0x2e, 0x6b, 0x01, 0x2f, 0x2e, 0x7b, 0xf7, 0xfb, 0x6f, 0xf0, 0x5f,
0xb8, 0x2e, 0x70, 0x50, 0x0a, 0x25, 0x39, 0x86, 0xfb, 0x7f, 0xe1, 0x32, 0x62, 0x30, 0x98, 0x2e, 0xc2, 0xc4, 0x41,
0x56, 0xa5, 0x6f, 0xab, 0x08, 0x91, 0x6f, 0x4b, 0x08, 0x9b, 0x56, 0xc4, 0x6f, 0x23, 0x09, 0x4d, 0xba, 0x93, 0xbc,
0x8c, 0x0b, 0xd1, 0x6f, 0x0b, 0x09, 0x81, 0x52, 0x9d, 0x5e, 0x56, 0x42, 0xaf, 0x09, 0x4d, 0xba, 0x23, 0xbd, 0x94,
0x0a, 0xe5, 0x6f, 0x68, 0xbb, 0xeb, 0x08, 0xbd, 0xb9, 0x63, 0xbe, 0xfb, 0x6f, 0x52, 0x42, 0xe3, 0x0a, 0xc0, 0x2e,
0x43, 0x42, 0x90, 0x5f, 0x87, 0x50, 0x03, 0x2e, 0x25, 0xf3, 0x12, 0x40, 0x00, 0x40, 0x28, 0xba, 0x9b, 0xbc, 0x88,
0xbd, 0x93, 0xb4, 0xe3, 0x0a, 0x89, 0x16, 0x08, 0xb6, 0xc0, 0x2e, 0x19, 0x00, 0x62, 0x02, 0x10, 0x50, 0xfb, 0x7f,
0x98, 0x2e, 0x5d, 0x0d, 0x01, 0x2e, 0x6b, 0x01, 0x31, 0x30, 0x08, 0x04, 0xfb, 0x6f, 0x01, 0x30, 0xf0, 0x5f, 0x23,
0x2e, 0x6d, 0x01, 0x21, 0x2e, 0x6e, 0x01, 0xb8, 0x2e, 0x01, 0x2e, 0x6e, 0x01, 0x03, 0x2e, 0x6d, 0x01, 0x48, 0x0e,
0x01, 0x2f, 0x80, 0x2e, 0x05, 0x0e, 0xb8, 0x2e, 0x9f, 0x50, 0x21, 0x34, 0x01, 0x42, 0x82, 0x30, 0xc1, 0x32, 0x25,
0x2e, 0x62, 0xf5, 0x01, 0x00, 0x22, 0x30, 0x01, 0x40, 0x4a, 0x0a, 0x01, 0x42, 0xb8, 0x2e, 0x9f, 0x54, 0xf0, 0x3b,
0x83, 0x40, 0xd8, 0x08, 0xa1, 0x52, 0x83, 0x42, 0x00, 0x30, 0x83, 0x30, 0x50, 0x42, 0xc4, 0x32, 0x27, 0x2e, 0x64,
0xf5, 0x94, 0x00, 0x50, 0x42, 0x40, 0x42, 0xd3, 0x3f, 0x84, 0x40, 0x7d, 0x82, 0xe3, 0x08, 0x40, 0x42, 0x83, 0x42,
0xb8, 0x2e, 0x95, 0x52, 0x00, 0x30, 0x40, 0x42, 0x7c, 0x86, 0x71, 0x52, 0x09, 0x2e, 0x62, 0x0f, 0x77, 0x54, 0xc4,
0x42, 0xd3, 0x86, 0x54, 0x40, 0x55, 0x40, 0x94, 0x42, 0x85, 0x42, 0x21, 0x2e, 0x6e, 0x01, 0x42, 0x40, 0x25, 0x2e,
0xfd, 0xf3, 0xc0, 0x42, 0x7e, 0x82, 0x05, 0x2e, 0xd7, 0x00, 0x80, 0xb2, 0x14, 0x2f, 0x05, 0x2e, 0x89, 0x00, 0x27,
0xbd, 0x2f, 0xb9, 0x80, 0x90, 0x02, 0x2f, 0x21, 0x2e, 0x6f, 0xf5, 0x0c, 0x2d, 0x07, 0x2e, 0x63, 0x0f, 0x14, 0x30,
0x1c, 0x09, 0x05, 0x2e, 0x77, 0xf7, 0x75, 0x56, 0x47, 0xbe, 0x93, 0x08, 0x94, 0x0a, 0x25, 0x2e, 0x77, 0xf7, 0xa3,
0x54, 0x50, 0x42, 0x4a, 0x0e, 0xfc, 0x2f, 0xb8, 0x2e, 0x50, 0x50, 0x02, 0x30, 0x43, 0x86, 0xa1, 0x50, 0xfb, 0x7f,
0xe3, 0x7f, 0xd2, 0x7f, 0xc0, 0x7f, 0xb1, 0x7f, 0x00, 0x2e, 0x41, 0x40, 0x00, 0x40, 0x48, 0x04, 0x98, 0x2e, 0x74,
0xc0, 0x1e, 0xaa, 0xd3, 0x6f, 0x14, 0x30, 0xb1, 0x6f, 0xe3, 0x22, 0xc0, 0x6f, 0x52, 0x40, 0xe4, 0x6f, 0x4c, 0x0e,
0x12, 0x42, 0xd3, 0x7f, 0xeb, 0x2f, 0x03, 0x2e, 0x78, 0x0f, 0x40, 0x90, 0x11, 0x30, 0x03, 0x2f, 0x23, 0x2e, 0x78,
0x0f, 0x02, 0x2c, 0x00, 0x30, 0xd0, 0x6f, 0xfb, 0x6f, 0xb0, 0x5f, 0xb8, 0x2e, 0x40, 0x50, 0xf1, 0x7f, 0x0a, 0x25,
0x3c, 0x86, 0xeb, 0x7f, 0x41, 0x33, 0x22, 0x30, 0x98, 0x2e, 0xc2, 0xc4, 0xd3, 0x6f, 0xf4, 0x30, 0xdc, 0x09, 0xa7,
0x58, 0xc2, 0x6f, 0x94, 0x09, 0xa9, 0x58, 0x6a, 0xbb, 0xdc, 0x08, 0xb4, 0xb9, 0xb1, 0xbd, 0xa5, 0x5a, 0x95, 0x08,
0x21, 0xbd, 0xf6, 0xbf, 0x77, 0x0b, 0x51, 0xbe, 0xf1, 0x6f, 0xeb, 0x6f, 0x52, 0x42, 0x54, 0x42, 0xc0, 0x2e, 0x43,
0x42, 0xc0, 0x5f, 0x50, 0x50, 0xbb, 0x50, 0x31, 0x30, 0x11, 0x42, 0xfb, 0x7f, 0x7b, 0x30, 0x0b, 0x42, 0x11, 0x30,
0x02, 0x80, 0x23, 0x33, 0x01, 0x42, 0x03, 0x00, 0x07, 0x2e, 0x80, 0x03, 0x05, 0x2e, 0xd5, 0x00, 0x33, 0x52, 0xe2,
0x7f, 0xd3, 0x7f, 0xc0, 0x7f, 0x98, 0x2e, 0x9c, 0x0e, 0xd1, 0x6f, 0x08, 0x0a, 0x1a, 0x25, 0x7b, 0x86, 0xd0, 0x7f,
0x01, 0x33, 0x12, 0x30, 0x98, 0x2e, 0xc2, 0xc4, 0xd1, 0x6f, 0x08, 0x0a, 0x00, 0xb2, 0x0d, 0x2f, 0xe3, 0x6f, 0x01,
0x2e, 0x80, 0x03, 0x51, 0x30, 0xc7, 0x86, 0x23, 0x2e, 0x21, 0xf2, 0x08, 0xbc, 0xc0, 0x42, 0x98, 0x2e, 0x91, 0x03,
0x00, 0x2e, 0x00, 0x2e, 0xd0, 0x2e, 0xb0, 0x6f, 0x0b, 0xb8, 0x03, 0x2e, 0x1b, 0x00, 0x08, 0x1a, 0xb0, 0x7f, 0x70,
0x30, 0x04, 0x2f, 0x21, 0x2e, 0x21, 0xf2, 0x00, 0x2e, 0x00, 0x2e, 0xd0, 0x2e, 0x98, 0x2e, 0x6d, 0xc0, 0x98, 0x2e,
0x5d, 0xc0, 0xab, 0x50, 0x98, 0x2e, 0x46, 0xc3, 0xad, 0x50, 0x98, 0x2e, 0xfc, 0xc5, 0x5d, 0x50, 0x98, 0x2e, 0x64,
0xcf, 0xb1, 0x50, 0x21, 0x2e, 0x7e, 0x01, 0xaf, 0x56, 0xb3, 0x52, 0x27, 0x2e, 0x7f, 0x01, 0x23, 0x2e, 0x80, 0x01,
0xb5, 0x50, 0x98, 0x2e, 0x53, 0xc7, 0xb7, 0x50, 0x98, 0x2e, 0x44, 0xcb, 0x10, 0x30, 0x98, 0x2e, 0x0d, 0xb6, 0x20,
0x26, 0xc0, 0x6f, 0x02, 0x31, 0x12, 0x42, 0xeb, 0x33, 0x0b, 0x42, 0x37, 0x80, 0x01, 0x30, 0x01, 0x42, 0xf3, 0x37,
0xbd, 0x52, 0xc1, 0x50, 0x44, 0x40, 0xa2, 0x0a, 0x42, 0x42, 0x8b, 0x31, 0x09, 0x2e, 0x5e, 0xf7, 0xbf, 0x54, 0xe3,
0x08, 0x83, 0x42, 0x1b, 0x42, 0x23, 0x33, 0x4b, 0x00, 0xbc, 0x84, 0x0b, 0x40, 0x33, 0x30, 0x83, 0x42, 0x0b, 0x42,
0xe0, 0x7f, 0xd1, 0x7f, 0x98, 0x2e, 0x0c, 0x02, 0xd1, 0x6f, 0x80, 0x30, 0x40, 0x42, 0x03, 0x30, 0xe0, 0x6f, 0xb9,
0x54, 0x04, 0x30, 0x00, 0x2e, 0x00, 0x2e, 0x01, 0x89, 0x62, 0x0e, 0xfa, 0x2f, 0x43, 0x42, 0x11, 0x30, 0xfb, 0x6f,
0xc0, 0x2e, 0x01, 0x42, 0xb0, 0x5f, 0xc1, 0x4a, 0x00, 0x00, 0x6d, 0x57, 0x00, 0x00, 0x77, 0x8e, 0x00, 0x00, 0xe0,
0xff, 0xff, 0xff, 0xd3, 0xff, 0xff, 0xff, 0xe5, 0xff, 0xff, 0xff, 0xee, 0xe1, 0xff, 0xff, 0x7c, 0x13, 0x00, 0x00,
0x46, 0xe6, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e,
0x2e, 0x00, 0xc1
uint16_t read_values_from_sensor_spi(uint8_t address_of_reg , uint8_t salve_device_cs_pin , bool bytes_16 = false)
digitalWrite(salve_device_cs_pin, LOW);
//read
SPI_1.transfer(0x80 | address_of_reg); // MSB
SPI_1.transfer(0); // dummy
uint16_t data_received = SPI_1.transfer(0); // actual data
if (bytes_16)
data_received |= SPI_1.transfer(0) << 8; // other bytes
// supports LSB first only
digitalWrite(salve_device_cs_pin, HIGH);
delayMicroseconds(10);
return data_received;
void setup()
pinMode(GYRO_CS_1, OUTPUT);
pinMode(LED_1 , OUTPUT);
// enable the sensor in SPI mode
digitalWrite(GYRO_CS_1, LOW);
delay(10);
digitalWrite(GYRO_CS_1, HIGH);
delay(100);
// enable the SPI interface
SPI_1.begin();
Serial.begin(9600);
delay(25);
SPI_1.beginTransaction(SPISettings(5000000, MSBFIRST, SPI_MODE0));
delay(100);
// Initailize the sensor according to quick start guide in data sheet
write_values_to_sensor_spi(0x59 , GYRO_CS_1 , 0x00);
SPI_1.transfer(0x5E);
for (int i = 0 ; i < 8192 ; i++)
SPI_1.transfer(bmi270_legacy_config_file[i]);
delay(2);
write_values_to_sensor_spi(0x59 , GYRO_CS_1 , 0x01);
delay(200);
void loop()
Serial.println(read_values_from_sensor_spi(0x21, GYRO_CS_1) , HEX); // status
void write_values_to_sensor_spi(uint8_t address_of_reg , uint8_t salve_device_cs_pin , byte data)
SPI_1.transfer(0x7F & address_of_reg);// write address
SPI_1.transfer(data);
delay(2);
You can see the sensor returns which means init-error
06-13-2023 04:22 AM
Hi Ansh521 ,
Official BMI270 driver code and exmaple code were written by C language on github, you can refer the example code https://github.com/boschsensortec/BMI270-Sensor-API/tree/master/bmi270_examples and migrate to your platform.
