05-29-2024 06:43 PM
Hi all,
The BMI270 sensor har built-in motion detections. We have a significant amount of accellerometer data sampled at various sampling rates from previous drive tests. The data set is labelled with timestamps, speed, and motion state. Is there any software simulators available, preferably in C or C++ code that will allow us to experiment with an emulated motion detection in a repeatable way, without using the actual BMI270 device.
For e.g. the "AnyMotion" detector there is 2 register values giving parameters for the detectior. With a software simulator we could quickly evaluate many different parameters based on our labelled data set.
Best regards,
Ola
05-30-2024 03:57 AM
Hi nisselua,
BMI270 significant motion detection also give parameters for the detectior, you can evaluate it with different parameters.
Besides, there is no other software simulation available.
