02-06-2024 05:10 PM
I am working on a project that interfaces with a BMM350 over I2C,
I have integrated the BMM350-SensorAPI into our project, and everything is working on all but one of our custom boards.
On one board I am seeing the init process fail during bmm350_magnetic_reset_and_wait(). Specifically when attempting to set the BR bit in the PMU_CMD register. BMM350-SensorAPI/bmm350.c:857
Where pmu_cmd_stat_0.pmu_cmd_value is: 0x00 instead of the expected: 0x07.
Is there any known reason for why this may be happening? I was unable to find anything related to this in the datasheet. If I comment out the error check and continue on with the init process then reading the magnetometer xyz data returns the reset values (0x7F7F7F).
02-21-2024 01:43 AM
Hi huntergw,
Could we know where did you purchase your BMM350 from?
How many BMM350 did you purchase? How many BMM350 initialization failures have occurred? How many BMM350 initializes normally?
05-11-2024 09:32 AM
currently we are also facing the same issue. Have you resolved the issue at your side?
J. Chandra sekhar
