    BMP585 Variant For Medical Device
    isaacgesser
    I am looking for a sensor similar to the BMP585 with a stainless steel or other non-corrosive biocompatible and autoclavable diaphragm.
    Does Bosch have such a device? If not, is there any way Bosch can help us develop such a device, possibly based on the BMP585 platform?
    Hi isaacgesser,
    Could we know more detailed information from you:
    What are the targets you need to test?
    What is your application environment like?
    Target: We need to test pressures from 0 to 15 psi absolute.
    Operating Environment: Low volumetric flow rate, 0 to 15 psia pressure sterile, buffered, aqueous solution containing any combination of sodium chloride, potassium chloride, calcium chloride, magnesium chloride and magnesium phosphate in a small volume, <100 microliter, titanium pressure chamber.
    Sterilization process: Autoclave 1000 cycles at 132C in steam (H2O). On occasion, the diaphragm/gel will be exposed to this steam (H2O), but the flow toward the sensor will not be impinging on the diaphram/gel and will be blocked most of the time. The sensor pressure chamber will be incased in metal, so the heat transfer will be approximetly 100%. Because this will be a medical device, the gel, if exposed to the fluid, must be biocompatible as well.
