2 weeks ago
In the datasheet its showing one pin Boot Load Indicator Pin 1o whats the use of that and how it works
Thanks for your inquiry. We will get back to you shortly.
Wednesday
BNO055 pin-10 is a debug pin which indicates Boot loader mode. It goes high once the boot loader becomes active. BNO055 keeps the output state of pin-10 at signal ground after the boot loader mode exits and the application code of BNO055 starts.
