    BNO055 what is current consumption in worst case mode
    Niels_R_M
    Hi
    I have a small technical question regarding BNO055 censor. What are the absolut max current consumption for this censor? We need the info to be sure we designed the supply correctly. The only info from the datasheet tells that the normal mode max current is 12.3mA, but no info of the max current in worstcase mode?
    / Niels Madsen
    FAE_CA1
    The max total supply current consumption of BNO055 is 12.3mA at temperature from -40C to 85C  and 9DOF sensor fusion mode at 100Hz output data rate continuously. This is the worst case current consumption which means that you will not see BNO055 current consumption more than 12.3mA at any other situation.
